REVIT VIEWER 2020 DOWNLOAD ?
MikeRhead
5,880 次查看
3 条回复
1 条消息(共 4 条)
MikeRhead
Morning,
Has revit removed the viewer mode for download I cant seem to find the download files anywhere.
Would love some help here
Joe
0 个赞
已接受的解答 (2)
5,881 次查看
3 条回复
回复 (3)
2 条消息(共 4 条)
TripleM-Dev.net
As fas as I know there's no (never been) a seperate viewer download/installation.
Next to the Revit full version there should also be a "Revit Viewer xxxx" icon shortcut.
It's just a command switch in the shortcut starting the full version into the viewer mode.
like: "C:\Program Files\Autodesk\Revit 2019\Revit.exe" /viewer /language ENU
AutoCAD has a seperate viewer download.. (DWG Trueview I believe)
0 个赞
3 条消息(共 4 条)
pendean
Community Legend
Community Legend
已接受的解答
You can always use the online viewer anytime in any webbrowser https://viewer.autodesk.com/
0 个赞
4 条消息(共 4 条)
mdavis22569
已接受的解答
HI @MikeRhead
Were you able to get this resolved?
As for an answer no, Autodesk didn't remove Viewer Mode. It's still part of Revit
Mike
Mike Davis
0 个赞
