REVIT ON WINDOWS 11
REVIT ON WINDOWS 11
charlie.murrayBPWN4
Observer Observer
Message 1 of 10
REVIT ON WINDOWS 11
charlie.murrayBPWN4
Observer
Observer
Hello All!
Has anyone been succesful working on windows 11 whilst working on a worksharing revit model?
I have been having issues since December! and I am still no closer to succesfully opening a revit project without it crashing on windows 11.
I took the plunge in buying a windows 11 PC after seeing autodesk products were supported.
Autodesk support have been great ... but still no solution and unable to use my new PC 😞
Any help would be greatly appreciated - Thank you!
Replies (9)
Message 2 of 10
HVAC-Novice
I don't, but this A-desk blog indicates 2019+ should work and to contact support if it doesn't.
Are you using the newest 2022 version and have contacted them if you have problems? the issue you have could be anything on Autodesk, or Windows, or your specific PC side.
Revit Version: R2026.4
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 3 of 10
fabiosato
I have no issues to work with workshared models on Windows 11.
Fábio Sato
Message 4 of 10
charlie.murrayBPWN4
Observer
Observer
Hello @Anonymous,
Thank you for your response.
Did you simply download revit and it worked straight out of the box? or did you have to make any changes?
Any assistance would be greatly appreciated.
Thank you.
Message 5 of 10
mdavis22569
Hi Charlie,
It also says make sure all of the updates are installed. Drivers are updated ...
I would make sure the video card driver is as well.
Then install Revit out of the box version .. and do addin's from there.  While Revit might work out of the box, that doesn't mean all of the addin's ( if you have them) would work on Windows 11
Mike Davis
Message 6 of 10
mdavis22569
@charlie.murrayBPWN4
Are you all set?
Mike
Mike Davis
Message 7 of 10
mhenseT43N9
Community Visitor
Community Visitor
What was the end result on this.  I am supporting a shop with all windows 11 surface studios and wondering what we can do to prevent the windows resource exhaustion warning.
Locking up PC 1x a week
I was duplicating floor views to make working areas in the model
Programs I had open at time: teams, ring central, Navisworks 2023, outlook, chrome
Need help to optimize these systems
i7 running 32gb ram
Message 8 of 10
Simon_Weel
Despite Autodesk saying it supports Windows 11, it's still work in progress. I wouldn't rely on Windows 11 for running my business applications yet. Especially with all updates thrown (err, trickle as MS calls it) at it, you're pretty much on your own if applications don't seem to play nice.
If it's a real big problem and you absolutely need to use that brand new pc, I would consider a downgrade to Windows 10?
Message 9 of 10
mdavis22569
Like Simon, I'm not a huge fan of W11 / Autodesk products right now.
There are a lot of C++/NET updates and they are causing issues with the tickets I've been seeing.
I'd monitor any an all Windows updates .. have an option to remove them if needed/possible.
Mike Davis
Message 10 of 10
pendean
Community Legend
Community Legend
i7 running 32gb ram
Start here
https://knowledge.autodesk.com/support/navisworks-products/troubleshooting/caas/sfdcarticles/sfdcart...
Then... Ask fellow Navisworks users in that forum for tips or recommendations too
https://forums.autodesk.com/t5/navisworks-forum/bd-p/372
And if needed... Open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options/we...
HTH
