Revit License
Revit License
simabitharGG3GR
Observer Observer
Revit License
simabitharGG3GR
Observer
Observer
Why does my revit show that it's expiring in 28 days? I tried to check my license and it shows a different expiry date which is about a year from now.. I'm kinda confused now is it expiring in a year or a month?
Thank you!
mdavis22569
HI @simabitharGG3GR
Because your PC can't reach the required Autodesk site for license verification:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Inventor-is-showin...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/What-URLs-protocol...
Mike Davis
Darin.Green
@simabitharGG3GR Expand the other Revit license within that dialog.  It may show a different expiration date.
If the other Revit license match the expiration date of 2024, then like @mdavis22569 said, your machine cannot reach the Autodesk Entitlement servers.
To check which urls are not reachable on your machine, use the Autodesk Licensing Support Tool
  1. Download and Extract the zip file
  2. Within the AdskLicensingSupportToolUI folder, double-click AdskLicensingSupportToolUI.exe to launch the UI
  3. Within the application, navigate to Connections, click Check URLs
  4. Check the Required urls and make sure Accessible is True
NOTE: api.autodesk.com being set to False is okay as long as you're not doing any api requests for custom programs.
If this information was helpful, please consider using the Accept Solution
