Revit Installation
Revit Installation
Revit Installation
I was installing revit software it got to 9 out if 19 it requested for the disk please what should I do
mdavis22569
Do you have the disk for it?
What version?
Mike Davis
natasha.l
Hello @Anonymous,
Welcome.
Have you checked the available disk space on your C:\ Drive?
Please review the Install error: "Not enough disk space" article. You want to verify if you have enough space for the application, you will need the following space available on the system to install.
  1. The actual download (Revit 2017 is 7GB)
  2. The extracted files (can be 2–3x the size of the download)
  3. The installation of the programs (can be 2–3x the size of the extracted files)
Remember to please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
mdavis22569
@Anonymous
See here is the same ticket as before
Mike Davis
natasha.l
Hello @Anonymous,
How did everything turn out did you have enough space after all or did you have to install the application on a different drive than C:\?
Let us know how it turned out.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
