Revit 2024.1.1 startup error Windows 11
km4504
Message 1 of 10
km4504
Does anyone get this error when starting Revit 2024.1.1 in Win 11?
If my reply was helpful, please give a Kudos or click the Accept as Solution button below (or both).
Replies (9)
Message 2 of 10
mdavis22569
Message 3 of 10
km4504
Thanks for the link, but I have been done this road 4 to 5 times and still doesn't work.
Message 4 of 10
mdavis22569
Did you reinstall the C++/NET?
I have seen a few others report this with 2024.1.1
Mike Davis
Message 5 of 10
km4504
Yes and removed it from the registry several times.
Message 6 of 10
mdavis22569
Do a clean uninstall / reinstall... don't install the 2024.1.1 .. see if you can get it going again
Mike Davis
Message 7 of 10
Simon_Weel
Is the file in question there? Is it blocked?
The file name suggests it has something to do with IFC. You could try installing the latest IFC Exporter to see if that resolves the problem
Message 8 of 10
mdavis22569
A lot of users are reporting this with 2024.1.1 @Simon_Weel
Mike Davis
Message 9 of 10
km4504
Where do I find the latest IFC Exporter?
Message 10 of 10
mdavis22569
https://up1.autodesk.com/2024/RVT/ADSKIFCExporterHelp_24_1_1.htm
Mike Davis
