Revit 2022 SCCM/Config Manager deployment
s.omar4KP5F
s.omar4KP5F
I'm using the Custom Install option to create a deployment for Revit 2022. When trying to install on various PCs it fails. When running the install script with basic UI I receive the error "Cannot Install. An error occurred while preparing the install. Please close the installation and start again" (as per attached image). I've had no problems packaging and deploying previous versions of Revit and CAD.
I looked up this error and have followed all the steps in the relevant knowledgebase article - removing ODIS and installing the latest version, turning off the firewall/security. I'm still unable to install.
Help?
natasha.l
Hello @s.omar4KP5F
Have you tried testing just the Revit 2022 deployment locally by itself? This should help narrow down the problem.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
s.omar4KP5F
Hi, if I run the Installer.exe file locally by itself then it also throws up the same error message.
