Revit 2020 installation error 1603
ParametricMonkey
Message 1 of 67
ParametricMonkey
I keep getting an error 1603 when trying to install Revit. I have uninstalled all old versions of Microsoft Visual C++ from 2010 onwards (as per some other suggestions) but am still getting the error message.
I've attached the log file. Any ideas how to fix this?
Replies (66)
Message 41 of 67
I tried again and now:
Message 42 of 67
Were you trying to install via the Browser Download method?
Your install is failing on the Visual C++ 2015 redistributables and Formit add-in...
2019/11/11:16:16:04 cecil DESKTOP-JVEE0HM Microsoft Visual C++ 2015 Redistributable (x86) return code: 1638
2019/11/11:16:16:04 cecil DESKTOP-JVEE0HM Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2019/11/11:16:16:05 cecil DESKTOP-JVEE0HM Microsoft Visual C++ 2015 Redistributable (x64) return code: 1638
2019/11/11:16:16:05 cecil DESKTOP-JVEE0HM Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
 2019/11/11:17:34:45 cecil DESKTOP-JVEE0HM Install Autodesk® FormIt Add-in for Revit® 2020 Failed Installation aborted, Result=1603
2019/11/11:17:34:45 cecil DESKTOP-JVEE0HM Component: FORMIT failed with code 1603   2019/11/11:17:34:45 cecil DESKTOP-JVEE0HM DoASPUninstall: productCode = {5E47699C-B0DE-443F-92AE-1D1334499D5E}
For the Visual C++ install issues, try this article.
Not sure about the Formit issue
Message 43 of 67
The last one I tried via Browser Download, and still unsuccessful.
Also uninstall the CC+ 2015 version and didn't work.
Message 44 of 67
The new report after uninstall the CC+
Pleaaase help me
Message 45 of 67
Looks like it's only failing on the Formit add-in now, maybe try installing the add-on separately first and then try the installer again?
https://formit.autodesk.com/page/formit-revit
Message 46 of 67
The problem here is the report saying that all was installed but none of the programs appears on my computer. Is the same image that I put here before, full of X in all components.
I dont know if you can understand me, if you need more explanation just tell, please. And thanks for the answer!
Message 47 of 67
I have the same problem and I can't fix it
Message 48 of 67
According to the install log, it's only failing to install Formit, but because the installer is so badly designed, it decides that the whole installation isn't worth anything if you can't have Formit and then strips all the software it has already successfully installed off your PC... that's what Rollback means:
So just try the Formit install first and see if that fails too and what the error is...
You might need to run the Microsoft Uninstall Tool first to get rid of any corrupt installations of the software first. Download the program, run it, choose "Problems uninstalling", then see if Autodesk Formit or Autodesk Revit 2020 appear on the list. If they do, use the program to uninstall them (it can only do one at a time, so you might need to run it twice). Clear the temporary files on your PC. Then try the Formit install first, if it succeeds, try the Revit install again. And remember to RUN AS ADMINISTRATOR
Edit: I have no idea why my reply is so weirdly formatted or why it says I'm responsing to myself since I clicked on reply to @Anonymous...
Message 49 of 67
Formit didn't give any problem but Revit can't be downloaded with Internet connection...
Without internet the installation succed by give the "License manager error" as always.
I will try to attach the Install log of this try.
Message 50 of 67
I replied to you here as you already have your own thread
Message 51 of 67
Hi all,
In the event it helps: I had the same problem. I only downloaded CCleaner and it repairs the Registry of the computer. Then, the installation was successful.
Message 52 of 67
  • please where is the solution
Message 53 of 67
Mark.Lancaster
@Anonymous
You need to provide your installation log file.  Each installation is different and something that you're faced with doesn't mean it has a solution here.   So without your installation log file we can only speculate what the issue is at this point.  So attach your installation file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Mark Lancaster
Message 54 of 67
log file
Message 55 of 67
Mark.Lancaster
@Anonymous
Most likely its linked to the new licensing mechanism but I need to see this log file as well C:\TESTTEMP\Autodesk Revit 2020 Install.log
Mark Lancaster
Message 56 of 67
ok
Message 57 of 67
Mark.Lancaster
@Anonymous
What sub-folders do you see here: C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing
And is this service there and running: 2020-01-07_18-45-01.jpg
Mark Lancaster
Message 58 of 67
that folders
it is not running
Message 59 of 67
Mark.Lancaster
@Anonymous
Right mouse click on the service and select to start.   Does it start?
Mark Lancaster
Message 60 of 67
yes
