Revit 2019- Installation error - Microsoft Visual C++ 2008 SP1 (error 1603)
 Hey Guys,
I am having a problem to install Revit on my computer.
I've installed AutoCad fine but Revit is causing problems. I have uninstalled all Microsoft Visuals C from the computer but the error still occurs
Mark.Lancaster
@Anonymous
An image of a failed installation is no use to us.. However in that same message of a failed installation, is a link to your installation log file. That's crucial in determining the root cause of a failed installation. At this point we can only speculate what the issue is.. So post your installation log file if you are still having an issue. If you do end up posting your installation log file, make sure to review it first to ensure there's no personal information such as your serial # in it.  Personal information such as your serial # should never be shared here.
Mark Lancaster
Sir
I have same question about autocad install fail in win10 1703
the detail information as below
the error message is below
2018/11/9:10:39:23 acer DESKTOP-706N9IA Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{23150069-68AE-4CA0-A05F-63482C6291EC}/STARTMARK...
2018/11/9:10:39:23 acer DESKTOP-706N9IA Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{23150069-68AE-4CA0-A05F-63482C6291EC}/VCREDIST2...
2018/11/9:10:39:23 acer DESKTOP-706N9IA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/9:10:39:25 acer DESKTOP-706N9IA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
A
Then I installed the Microsoft Visual C++ 2008 and it show as below
Error 1935.An error occurred during the installation of assembly 'Microsoft.VC90.ATL,version="9.0.21022.8",publicKeyToken="1fc8b3b9a1e18e3b"
B
then installed NET Framework 4.7.2 and 4.62 and the result was fail
Pls help me to solve the issue.
Quennel
BJ.C
Hello @Anonymous
I would suggest trying an install using the Browser download method.
What operating system are you currently using - Windows 7, 10??
The issue looks similar to the following post:
https://helpx.adobe.com/creative-suite/kb/error-1935-assembly-component-microsoft.html
Thank you for taking part in our community forum!
Kind Regards,
BJ.C
Technical Support Specialist
Sir
Thanks for your information’.
I used to the Browser download method for install and can't any software in
the autodesk account as attachment
Then I use other account and used to the Browser download method for 2016
and 2017.the result was failed.
The reason is same. Microsoft Visual C++ 2008 SP1 Redistributable (x86)
Failed
Kind Regards
Quennel
