Revit 2018 Installation
Hello, I have a lot of troubles installing Revit 2018 IT. When I try to install the software it says: Autodesk Revit Content Libraries 2018 it's already installed but at the end when I open Revit a lot of files of default are not present. The first error it's: "Il percorso specificato per i file modello di famiglia di default non è valido" (default files of the families miss).
Before installing Revit 2018 IT, I uninstalled everything, Revit 2017-2018 ENG, everything! I really don't know how to do. Can you help me?
dill.khan
Try using the instructions in the link
link: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
I hope I could help you
When that helps you than give me a Kudo and recognize it as a solution
Best Regards
dill
