REVIT 2017 INSTALLATION
Message 1 of 10
every time i try to install revit 2017 64 bi on my windows 7 64 bit os
the setup terminates automatically.
i tried other measures like uninstaling previous .net and visual c++ redistributable programs.
but proved to be of no use.
my workstation config is as follows:
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.160211-0600)
System Manufacturer: INTEL_
System Model: DB85FL__
Processor: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz (8 CPUs), ~3.4GHz
Memory: 8192MB RAM
DirectX Version: DirectX 11
Card name: Intel(R) HD Graphics 4600
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_20528086&REV_06
Dedicated Memory: 1024 MB
Replies (9)
Message 2 of 10
markcalloway
I have had a look at the installation log and it looks like it terminates unexpectedly, the installation encounters an issue installing Microsoft Visual C++ 2005 Redistributable (x64) but then terminates instead of rolling back the installation.
Normally I would recommend that you uninstall all versions of Visual C++ and try again but if you've already don't this then this isn't the issue.
You could always try and install Microsoft Visual C++ 2005 Redistributable (x64) from the Revit installation files separately and see if it installs OK and if you get an error that might gives us more to go on. The installer for Microsoft Visual C++ 2005 Redistributable (x64) can be found here:
C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe
Let us know if this helps,
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
Message 3 of 10
installation error
Message 4 of 10
setup terminates the same way but with different log details
Message 5 of 10
markcalloway
Is this the error you get when install Visual C++ from the autodesk installation directory?
Please can you attach a screenshot of any error messages to your post as well please.
Message 6 of 10
error 2381 message occured when i ran "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe"
but when i ran "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe"
it installed without any error and prompted to restart the system following which i clicked yes to restart.
after a restart i tried running it with administrative privileges but again  it terminated the same way.
Message 7 of 10
Mark.Lancaster
@Anonymous
Use the 1603 error link in my signature and confirm if any of the solutions resolve the issue.  Report back on your progress.
Mark Lancaster
Message 8 of 10
this is how it looks like after setup termination
Message 9 of 10
markcalloway
Looks like the install of Microsoft Visual C++ 2005 is the cause of your issues.
You could try and download Microsoft Visual C++ 2005 Redistributable Package (x64) from Microsoft and see if it will install:
https://www.microsoft.com/en-gb/download/details.aspx?id=21254
If it still errors when downloaded directly from Microsoft then this is a fault on your computer and not related to your Autodesk software and you may need to contact your IT department.
If Microsoft Visual C++ 2005 installs from Microsoft, please try and install Revit again and see if it now works. If Revit still fails please re-download Revit in case it didnt download correctly the first time.
Message 10 of 10
Darin.Green
Hi @Anonymous,
The easiest solution is to edit the setup.ini file which is found in the same location as setup.exe the search the file for "3rdParty\x64\VCRedist\2005\vcredist_x64.exe".
Once you find it within the file, delete the entire line then save it back to its original location. Then run the installation again.
If this information was helpful, please consider using the Accept Solution
