Revit 2017 activation code
please I wanna serial number for revit 2017
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
This is a user forum and users don't send other users serial #s for the product.  Serial #s come from Autodesk when your subscribe to (paid for) the product or you are a student attending a qualified educational institution.
Where do you fall under?
Mark Lancaster
natasha.l
Hello @sasoooooo,
Welcome to the community.
To activate you should review the information below:
  1. If, you are eligible for Educational Software Create an Account
  2. Review the Steps for Setting-Up Student Software, the educational site will provide the Serial # & Product Key
note: added this info for you
  1. Depending on the download method it will automatically recognize your credentials & sign-in or you manually type in the serial# & product key (you shouldn't need an activation code)
  2. Temporarily disable security settings like Antivirus, Firewall & UAC on your Windows operating system
  3. An internet connection is required to activate, every 30days you should be connected to the internet at some point (to verify your license & use the software) Adjust your proxy settings, to allow access during the install & first launch, also make sure you have an uninterrupted connection. You can try another Wifi network location
  4. If the online method does not work & you need an activation code for offline activation, request one here by using Register.autodesk.com
Thank you for posting & let us know if you need some more help activating.
Please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello sasoooooo,
I wanted to check-in with you, please review the last post it runs through everything you will need to set up your educational software.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
