Renewed Education License but AutoCad still popping out 'Access Expired
kenji0660
Message 1 of 17
kenji0660
Hello, Im Kenji
I have renewed, I tried 3Ds Max is fine. But only my AutoCad cant seem to access.. I have tried to reinstall thrice but cant seem to access.. I have checked the license expiry date from both 3Ds Max and AutoCad. Only 3Ds Max have updated, AutoCad remained the same
Replies (16)
Message 2 of 17
mdavis22569
HI @kenji0660
What's the error you're getting for AutoCAD?
Mike Davis
Message 3 of 17
mdavis22569
Also noticing the sign in name is different on AutoCAD vs 3DS Max
Try resetting the license
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
Mike Davis
Message 4 of 17
kenji0660
Hello Michael Davis,
I have tried to resetting the license using the link you have sent me. Still facing the same problem.
Even though the name is different from autocad vs 3dsmax. The account is same for both
Message 5 of 17
rushabhthakkar_910
@mdavis22569, The name is same in both the images..!! (kenji0660)
@kenji0660, Have you received any email like this for AutoCAD..??
Also have you requested for a New License for AutoCAD from Educational Website..??
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 6 of 17
kenji0660
Hello.
Yes I have renewed my student license and have received the email same as the picture u sent me.
My 3dsmax is working fine and the license have updated. only my auotcad not.
Not sure why. I have tried to reinstall couple times to try to trigger the license but cant seems to work.
Message 7 of 17
mdavis22569
Hmmm I'd look again @rushabhthakkar_910
I put some arrows to help you out @rushabhthakkar_910
@kenji0660  Make sure you have a valid subscription still.. it doesn't look like it.
Says Feb 16, 2023,   it's now Feb 20, 2023
Mike Davis
Message 8 of 17
rushabhthakkar_910
@kenji0660, Okay. So as the date has passed and license has expired. Are you still able to access it or getting any error's..??
Thanks and Regards,
Rushabh Thakkar.
Message 9 of 17
kenji0660
Here is a proof that I have renewed the license..
Hmm not sure why is the username different, but i can confirm that the account is same for both.
As u can see the ID is same
Message 10 of 17
mdavis22569
Why the 2 different names on the PC?
This will cause a conflict with the Single User Sign On?
Mike Davis
Message 11 of 17
kenji0660
Apparently, I did not make any changes for the username of both.
I installed, log in and that's it.
The username appear different from the time I log in.
Message 12 of 17
mdavis22569
Where is the proof?
I don't see AutoCAD listed
Mike Davis
Message 13 of 17
mdavis22569
Are these both Educational?
Thinking your licensing on the PC needs to reset for everything and re-logged into
M
Mike Davis
Message 14 of 17
kenji0660
Here, I have tried to reinstall.
Message 15 of 17
mdavis22569
Thank you .. now I see it
Mike Davis
Message 16 of 17
kenji0660
Yes everything from autodesk is student licensed. All installed using the same account.
Message 17 of 17
mdavis22569
Something is off ..
Especially with all the different names.
Honestly, I'd probably uninstall it all .. or reset it all.  Just my opinion.
Mike Davis
