Regarding Global Travel Rights
Message 1 of 11
Dear,
I have a question regarding Global Travel Rights, it stated - Use outside of the country of purchase when purchased in home country.
How long it can be used outside the country? Is there any terms?
Best regards,
Huam SK
Replies (10)
Message 2 of 11
edwin.prakoso
Maybe this can help Global Travel Rights.
It seems that you can only use it outside of the home country if you are on subscription.
There is a list of examples and scenarios that might match your condition at the bottom of that page.
Cheers,
Edwin Prakoso
Message 3 of 11
Dear Edwin,
Thanks for your reply. Anyway, it didn't mention up to how many days it can be used outside the home country. Someone told us that it is 90 days, but we have to verify that.
Best regards,
Huam SK
Message 4 of 11
edwin.prakoso
I remember the limitation was mentioned before in FAQ, but I can't find it anymore. Yes, it was 90 days.
The limitation probably has been removed. What is your subscription model? Maintenance Plan or Subscription?
This is the global travel rights benefits for the maintenance plan. It also doesn't mention about time limitation.
Cheers,
Edwin Prakoso
Message 5 of 11
Dear Edwin,
Thanks for your reply. Yes, our license model is subscription.
Best regards,
Huam SK
Message 6 of 11
edwin.prakoso
I have the confirmation from Autodesk support that the 90 days limitation still applies.
You can only use the license outside of your home country for 90 days.
Cheers,
Edwin Prakoso
Message 7 of 11
Is this time limit still applicable?
If so, shouldn't it be stipulated in the Terms and Conditions?
Message 8 of 11
Mark.Lancaster
@Anonymous
First you replied to a posting that's over 2 years old..  Things have changed..
ETR (Extra Territory Rights)  which is the new travel definitions are now based on the term length you have.  There's no 90 day limitation now.   For example if your term (subscription or maintenance plan) expires in 6 month, then your ETR is only good for 6 months.  If it expires in 3 years, your ETR is permitted for 3 years.
Mark Lancaster
Message 9 of 11
Hey @Mark.Lancaster, thank you for weighing in.
Sorry for being imprecise, I was referring to the Global Travel Rights - they were already discussed in this thread so I thought I'll use this thread instead of creating a new one.
I have reviewed all the documentation on Global Travel Rights that I can find and it does not mention a time limit anywhere:
https://www.autodesk.com/company/terms-of-use/en/subscription-benefits
https://knowledge.autodesk.com/customer-service/account-management/users-software/global-travel-righ...
https://www.autodesk.com/company/legal-notices-trademarks/autodesk-terms-and-conditions/eng_autodesk...
I also heard on the grapevine that it is/used to be 90 days so wanted to confirm, but Autodesk agents have reported conflicting opinions.
Message 10 of 11
Mark.Lancaster
@Anonymous
Sorry I was also thinking this morning...
I should not had said ETR in my discussion.   Too early to think..
ETR is something else where it gives a company the right to purchase global licensing (and technically doesn't have anything to do with travel conditions)..     My bad..
When traveling, global rights (correct term), the length of duration is solely based on the term length as I indicated early.  Yes there use to be a 90 day limitation but that changed when subscription type license came onto the market.
Mark Lancaster
Message 11 of 11
freddbarton
Community Visitor
Community Visitor
Please have a look at flight pro international and get the help about Regarding Global Travel Rights.
