"Installation Incomplete. Some products failed to install."
FayetallyGay
Message 1 of 10
FayetallyGay
I've been trying to install AUTOCAD 2017 for students for the past 7 hours, no luck. Installation will get about half an hour in, then jump to the finish screen showing that all products failed to install. Here's the latest log.
Replies (9)
Message 2 of 10
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Your log file shows the errors 1603 and 1619, for that you can already find a lot of suggestions and solutions >>>click<<<
Good luck, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 10
Mark.Lancaster
@FayetallyGay
This posting appeared as new but its a few days old..  Have you resolved your issue?
If not your installation is failing due to the method you're using..
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Mark Lancaster
Message 4 of 10
Sorry, I did manage to install AutoCAD successfully, I tried the method you suggested, and many others, but with more or less the same result. I ended up just doing a full factory reset for my PC. Your method worked  afterwards, so thank you.
Message 5 of 10
FayetallyGay
That's weird, I got automatically signed in to an old account
Message 6 of 10
This message states that there is a link for downloading the proper way, but I do not have access to that link, is it still available?
This is the exact issue I am having. Thankfully I am only 3 hrs into instead of 7, but I do not want to go for 7 hours...
Message 7 of 10
Mark.Lancaster
@Anonymous
Welcome to the community..
1. Access the Autodesk Virtual Agent and follow the download links to your product.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
 Good luck on your installation and report back on your progress.
Mark Lancaster
Message 8 of 10
i am having the same problem, it says some products failed to install. could you help me download autocad
Message 9 of 10
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Without your installation log file we can only speculate what the issue is at this point.  So attach your installation file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Mark Lancaster
Message 10 of 10
This is my log file sir. what will be the problem sir?
