"Autodesk Analytics Client Service" process can't be deactivated by default
francesco.menara
Observer Observer
francesco.menara
Observer
Observer
Good morning there,
I'm writing in this forum because I use an educational AutoCAD license so the official support tells me I can't directly contact them, and I should tell the administrator to write them and I don't want to disturb the university technicians for such a small problem.
The problem is that, in fact, when I use AutoCAD a process called "Autodesk Analytics Client Service" uses a lot of CPU, which wouldn't have been a problem if I worked from a desktop PC; the fact is that I actually work on a laptop, so higher CPU usage means shorter battery life and a lot of noise from the fans. I disabled the analytics service from the menu near the "Help" ("?") button and then I checked the registry key which is correctly set to 0, but the process still runs when I open AutoCAD. Any solution is welcome.
Thank you very much indeed.
natasha.l
Hello @francesco.menara,
To resolve this error exclude the ADPClientServices.exe and AcExperience.arx within your security settings.  The only other option is to disabled data analytics.
How to set up antivirus (AV) exclusions to improve stability and performance of Autodesk software
How to enable or disable the Desktop Analytics Program from within Inventor
How to remove ADPClientServices.exe from an Autodesk software installation
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
francesco.menara
Observer
Observer
Thank you for your answer; where can I find the service you mentioned? I can't see it in msconfig. Sounds it could be the right way to solve the problem. I already disabled data analytics via Autocad's interface.
Thank you again
F
