"Autodesk Analytics Client Service" process can't be deactivated by default
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good morning there,
I'm writing in this forum because I use an educational AutoCAD license so the official support tells me I can't directly contact them, and I should tell the administrator to write them and I don't want to disturb the university technicians for such a small problem.
The problem is that, in fact, when I use AutoCAD a process called "Autodesk Analytics Client Service" uses a lot of CPU, which wouldn't have been a problem if I worked from a desktop PC; the fact is that I actually work on a laptop, so higher CPU usage means shorter battery life and a lot of noise from the fans. I disabled the analytics service from the menu near the "Help" ("?") button and then I checked the registry key which is correctly set to 0, but the process still runs when I open AutoCAD. Any solution is welcome.
Thank you very much indeed.
