Problem with installation of SP2 for autocad architecture 2015
I was very happy with the 2014 version. I upgraded to the 2015 version not because I wanted to, but because I upgraded my desktop to a newer stronger one and the only option available was to install the 2015 version. I found many problems in the 2015 version. Things which worked fine in the 2014 version wre not working properly in the 2015 version. I think that installing the sp2 might solve some of the problems. I tried to install the sp2 but I am getting an error message which states that the installation cannot continue because Microsoft .net 4.5 is not installed on my system. The point is that .net 4.7.1 is installed on my system, so the question is how to overcome this problem. The error code by the way is 1603.
Hi Markus
Your reply relates to WIndows 10 and Windows 8. I am using windows 7. Can you refer me to a relevant solution?Thanks, Ofer
m_latz
It is also for Windows 7:ProblemDotNet45.png
regards
Markus
