Problem with AutoCAD 2018 installation (student license)
Hi, i can't get my activation code. Could you please help me?
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
You need to tell us why you can't..  Message?  Show us what you're seeing.
Mark Lancaster
When I come to https://registeronce.autodesk.com it calls me to contact support that I have a technical issue or when I open my AutoCAD 2018 a I click on button Activate and Activate online it calls me another issue.
I start AutoCAD, then I click on Activate, Activate right now online (Recommeded) and then it tells me error 400, sign a form a fill it.
natasha.l
Hello @Anonymous,
Welcome.
Sorry for the frustration. If you are connected to a limited network environment try another network/wifi environment. If you have access to a cafe or private network try that. Also please take a look at the information below.
How to activate Educational Software
  1. Review the Steps for Setting-Up Student Software depending on the download method it will automatically recognize your credentials & sign-in or you manually type in the serial# & product key (you should not need an activation code)
  2. Temporarily disable security settings like Antivirus, Firewall & UAC on your Windows operating system
  3. An internet connection is required to activate, every 30days you should be connected to the internet at some point (to verify your license & use the software) Adjust your proxy settings, to allow access during the install & first launch, also make sure you have an uninterrupted connection.
  4. If the online method does not work & you need a activate code for offline activation, fill out this form with the educational support team or use Register.autodesk.com
Thank you for posting. Smiley Happy
Please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello @Anonymous,
Just checking in with you, hope you were able to resolve this & activate. Let us know how it is coming along.
Please remember to "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
