Problem loading acadres.dll resource file
- Mute
- Permalink
- Report
AutoCAD 2018 and Windows 10 64-bit.
When AutoCAD is launched, a message box pops up with the unhelpful error message "Problem loading acadres.dll resource file".
The reason there is a problem is because the file does not exist in any of the program folders. The file does exist in the setup folder (offline installer) but it's clearly not being copied across to the program folder during installation.
I have uninstalled/reinstalled AutoCAD several times, including all 8 of the Microsoft C++ redistributables, antivirus disabled, cleaned the registry and removed all traces of Autodesk from the system. I have also run the Microsoft FixIt tool. Yet this one file simply refuses to be installed. There are no error messages during installation.
I have also tried manually copying the file across. I assumed the correct location was C:\Program Files\Autodesk\AutoCAD 2018\en-us however that's clearly not the case. So, to which folder does this file actually belong and why isn't it being installed?
I have Googled for this error and it is apparently a problem that has existed as far back as AutoCAD 2005!
