Problem installing Autodesk Inventor Pro 2020 due to error 1603 (need unconventional solutions)
The error screenshotThe error screenshot
Here is the log file.I tried all the solutions reccomented by Autodesk regarding error 1603 like installing directly with an installer,clear temp Program files residual and the similar others,updating license etc.The main error i guess is regarding licensing and i'm worried if my license varification was not done propperly.Please help if you have this problem specific solution.
2020/11/22:08:34:56	ADITHYA ASHOK	ADITHYA	AnalyzeInstallFailure() GetErrorContext returned: Error String fatal error
2020/11/22:08:34:56	ADITHYA ASHOK	ADITHYA	AnalyzeInstallFailure() QueryAknURL returned: AKN Article https://knowledge.autodesk.com/search?p=INVPROSA&search=fatal error&sort=score&page=1&v=2020
2020/11/22:08:34:56	ADITHYA ASHOK	ADITHYA	AnalyzeInstallFailure() error 28672 mapping not found in error.xml
2020/11/22:08:35:00	ADITHYA ASHOK	ADITHYA	Rollback	Autodesk Single Sign-On	Succeeded
2020/11/22:08:35:00	ADITHYA ASHOK	ADITHYA	Rollback: Autodesk Licensing 	 component is exe :Ignored Rollback.
2020/11/22:08:35:00	ADITHYA ASHOK	ADITHYA	Rollback: Universal C Runtime (KB3118401) 	 component is exe :Ignored Rollback.
2020/11/22:08:35:00	ADITHYA ASHOK	ADITHYA	Rollback: Microsoft Visual C++ 2013 Redistributable (x64) 	 component is exe :Ignored Rollback.
2020/11/22:08:35:00	ADITHYA ASHOK	ADITHYA	Rollback: Microsoft Visual C++ 2013 Redistributable (x86) 	 component is exe :Ignored Rollback.
leowarren34
Hi @Anonymous,
Can you upload the entire installation log file?
It's not going to be a licensing issue as licensing and installation are separate issues, for a license to be activated the software first needs to be installed.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
@leowarren34 thanks a lot for replying.I have attached the log file.
2020/11/21:22:02:44 ADITHYA ASHOK ADITHYA Download Error Network is disconnected SOLUTION_PROVIDER_PACKAGE https://emsfs.autodesk.com/utility/SolutionFramework/FY19/
Are you trying via "Download Now"?
@AnonymousThank you for the response.I have tried downloading it both ways(install & download).
@Anonymous For me the options were Install & Download. Tried them both. Thanks anyways.
It's fine now since i reinstalled Windows 10.
