Problem installing AutoCad 2018
Message 1 of 10
Cuando intento instalar Autocad, me sale el siguiente error que adjunto en dos pantallazos, he instalado Revit y no me ha dado problema alguno.
< Edited Content for better support. >
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
Message 3 of 10
natasha.l
Google Translate
When I try to install Autocad, I get the following error that I attached in two screens, I installed Revit and it did not give me any problems.
Hello @Anonymous,
Thank you for posting. I have translated your post for you this is an English forum, please translate your posts for better feedback in the future. Please take a look at the Steps for Setting-Up Student Software post it will guide you through the process.
Before downloading & installing.
  1. Log in as an Administrator
  2. Empty your TEMP folder. To open the TEMP folder, type %TEMP% in the address bar of Windows Start Menu and hit Enter
  3. Temporarily disable your Antivirus software & Firewall
  4. Temporarily disable UAC:  Windows 7 , Windows 10
The Drop Down will give you other options like "Download Now" or "Browser Download".
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Message 4 of 10
Ok thank you so much but the error still appears, I don´t know how Can I do it? I have no problem installing other Autodesk softwares.
Thank you
Message 5 of 10
natasha.l
Hello @Anonymous,
I would try using AIDA logs to troubleshoot installation errors, download the installation executable from the following link to download AIDA.
2. Double-click the executable and click the “Install” button
3. Accept the license agreement and click “next”
4. Click the “Install” button. The install should complete in 1-2 minutes. Click “finish” when complete
Also, there is a known Autodesk issue you might be having issues getting info and downloads in Autodesk Account right now. Sorry for the inconvenience; working to fix this ASAP!
Message 6 of 10
Thank you so much, but the problem still appears. I attached the file from AIDA because some lines are red so I suppose that are wrong or it has some error.
Thank you again
Message 7 of 10
Mark.Lancaster
@Anonymous
Logs are showing you don't have the proper permission on your machine.  Make sure your Windows account has full admin rights to your machine.
Mark Lancaster
Message 8 of 10
Hello, Thank you so much, but my problem still appears. Now I have installed AIDA as a user told me but the error 1606 still appears. I attached the file obtained from AIDA.
Thank you so much again.
Message 9 of 10
@Mark.Lancaster thank you so much. I think that I have administrator permission, I will show you a screenshot of my account.
Message 10 of 10
Mark.Lancaster
@Anonymous
If you're getting at 1606 than see this article and its solutions.
Mark Lancaster
