Problem installation Autocad Map 2015 "already installed"
Hello (sorry for my english)
I've a problem : I had an error when installing the first time Autocadmap 3D 2015 on Win 8.1 (64bit) - it stops ...
Then I tried to reinstall and it does'nt work : it says "Autocadmap already installed"
I have uninstalled all products autodesk (following : http://knowledge.autodesk.com/customer-service/installation-activation-licensing/get-ready/remove-pr... also clean uninstall Autocad 2015
Then I reinstall Autocad 2015 : it works, but then I tried to reinstall Autocadmap 3D 2015 again and it still says me "Autocadmap already installed"... (same message...) ... I searched on internet but i didnt found solutions.
What should I do to fix it ?
Thank you;
philip.s
Hello and welcome to the community @Anonymous!
One of the best workarounds when a program cannot be installed because the installer indicates that it is already installed (but isn't), is to run Microsoft Fixit.
The typical cause for such an error is caused by a prior install that has failed, left residual keys in the registry that make the installer think the program is already installed.
Failed Install - Program lists as already installed
Here to help if additional assistance is needed, otherwise please accept as a solution so that others can benefit from this information.
Thanks a lot!
I didnt knew Fixit !
