Possible to customize installation to EXCLUDE Autodesk Desktop Connect Service?
jferrell77
Message 1 of 12
jferrell77
I'm working on upgrading my users to Inv Pro 2019. Unfortunately, during the install our AV program is blocking the tmp msi file that is created when 'AutodeskDesktopConnect.msi' is ran. It will still install Inventor properly, but when I then try to install Inventor2019.1 update, AV blocks it again, and that install will fail completely.
Is it possible to install Inventor or the update without having to include the Desktop Connect Service? I've looked into the custom install settings and there was no option to not include it, so I am wondering if their is some special workaround without having to disable AV (IT is not in favor of this).
Replies (11)
Message 2 of 12
SBix26
I don't know the answer, but you're much more likely to get it in the Installation & Licensing Forum.
Sam B
Inventor Pro 2019.1.1 | Windows 7 SP1
LinkedIn
Message 3 of 12
jferrell77
Great idea. Thanks!
Message 4 of 12
DarrenP
you can probably modify the setup.ini to not install the desktop app would be the only way i know
DarrenP
Message 5 of 12
m_latz
What you can do is extract the msi patches (msp files) and msi files from the update exe package (WiX) and install only those parts you need.
The package contains the following updates:
regards
Markus
Message 6 of 12
natasha.l
Hello @jferrell77
Thank you for posting.
The Autodesk Desktop Connector service is required to connect to Autodesk servers. Please try the following steps below:
  1. Please temporarily disable security settings like Antivirus, Firewall & UAC on your Windows operating system.
  2. Also, be sure you have Windows Administrator permissions while installing the update.
  3. Adjust Lan Settings & Proxy Settings
Let us know if you have any questions.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 7 of 12
jferrell77
@natasha.lThanks, but IT is looking for a solution that doesn't require disabling our AV software every time we have to do an install. As far as being required to reach the servers, I don't think that is something we need to be able to do.
Message 8 of 12
jferrell77
@m_latzThanks! That seems like the best option for now. How can I extract the files?
Message 9 of 12
m_latz
@jferrell77,
as I said, the developers used WiX (Windows Installer XML) to build the package.
There is a WiX Toolset available, with which you can extract the files.
Try to download https://github.com/wixtoolset/wix3/releases/download/wix3111rtm/wix311-binaries.zip
Extract to a folder and use:
dark.exe Inventor2019.1.exe -x .\out
Then all parts of the package are extracted to the ".\out" folder.
Look at the .\out\AttachedContainer folder, there you find all msi and msp packages.
Hope that helps.
regards
Markus
Message 10 of 12
jferrell77
@m_latz I'm sorry, but apparently I am going to need a more dumbed down version of your instructions.
I was able to download the wix311, but I cannot do anything with it. I'm not sure exactly what you mean by:
Use it where exactly?
Message 11 of 12
m_latz
Okay,
I've created a short film to show the usage.
dark usage from WiX (Windows Installer XML)
If you have further question let me know.
regards
Markus
Message 12 of 12
jferrell77
@m_latz
You are AWESOME! Thanks so much!
