Network license stoped working
Moshe-A
Mentor Mentor
Message 1 of 9
Moshe-A
Hi guys,
Recently we had to move the cable network from 1 NIC to another on the same server (of course we moved the server ip address) we generate a new LIC file with the new MAC address, config it in lmtools but lmtools identifies another NIC on the server - solusion?
thanks in advance
Moshe
[ The subject line of this post has been edited for clarity by @handjonathan Original: our network license stop working ]
Replies (8)
Message 2 of 9
Simon_Weel
Maybe this article wil help?
Message 3 of 9
Moshe-A
@Simon_Weel ,
thanks you for this reply.
Just to make it clear as you can see in picture the ip address lmtools is recognizing is APIPA, and this the other NIC the server holds, actually it is a virtual NIC.  can i ignore it?
Moshe
Message 4 of 9
Moshe-A
check it, it can not be ignore
Message 5 of 9
mdavis22569
What's the error code you're getting?
Is everyone on the 11.18?  Most current version of the NLM?
Mike Davis
Message 6 of 9
Simon_Weel
The field 'Ethernet' lists the MAC-address - which in your case is rather long? It looks like a bunch of combined MAC-addresses. If you check the machine's 'Network connection details' (or perform 'ipconfig /all' from a command line) then it should list the MAC-address with the IP-address tied to that MAC-address. Make sure that MAC-address is the only one in the license file (server FSERVER <MAC address>).
Message 7 of 9
yael
@Simon_Weel ,
some how it started to work i do not know how \ why, hope it will stay long
thank you
Moshe
Message 8 of 9
Simon_Weel
For updates on the NLM manager - read the installation notes carefully. You need to remove all existing files before installing the update. If you don't (like I did), not all files will be updated which could result in problems later on.
Message 9 of 9
mdavis22569
@Moshe-A
Just checking in to make sure you're all set...
Mike
Mike Davis
