Network License Manager Error [0.0.0]
Message 1 of 13
Hello together.
We have installed the Network Licenes eManager using the Manuel.
The Server status within LMTOOLS looks good. The firewalls on the Server and the client are down during the test.
On the client: The LGS.data file is set to _NETWORK and the LICPATH.lic contains the correct Servername.
On the Client we get the error [0.0.0] Networklicense unavailable by starting AutoCAD 2017
Has anybody an idea? Thanks.
Here some logs:
LMTOOLS Server Status:
Status
Flexible License Manager status on Tue 5/9/2017 14:32
[Detecting lmgrd processes...]
License server status: 27000@SVR-CAD-01
    License file(s) on SVR-CAD-01: C:\Autodesk\Network License Manager\SVR-CAD-01005056956d78.lic:
SVR-CAD-01: license server UP (MASTER) v11.13.1
Vendor daemon status (on SVR-CAD-01):
  adskflex: UP v11.13.1
Feature usage info:
Users of XXXX6ADSTPR_T_F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of XXXX7ADSTPR_2018_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of XXXX2ADSTPR_2017_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of XXXX7ADSTPR_2016_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of XXXX0ADSTPR_2015_1F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of XXXX5ADSTPR_2015_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
(the first four numbers whre changed)
on the client:
3964    2017/05/09    14:05:04    Reason=Fatal error
3964    2017/05/09    14:05:04    ComputerName=XXXXX
3964    2017/05/09    14:05:04    OS=6.1.7601.Service Pack 1
3964    2017/05/09    14:05:04    File=AdlmIntNWFBLicense.cpp,Line=802
3964    2017/05/09    14:05:04    VendorID=3 [FLEXLM-NW]
3964    2017/05/09    14:05:04    VendorError=-1 [Cannot find license file.]
3964    2017/05/09    14:05:04    FLEXLM-NW=v11.13.1.0 build 167164 x64_n6
3964    2017/05/09    14:05:07    Reason=Fatal error
3964    2017/05/09    14:05:07    ComputerName=XXXXX
3964    2017/05/09    14:05:07    OS=6.1.7601.Service Pack 1
3964    2017/05/09    14:05:07    File=AdlmIntNWFBLicense.cpp,Line=785
3964    2017/05/09    14:05:07    AdlmIntError=20 [License check out failed]
5640    2017/05/09    14:14:49    Reason=Fatal error
5640    2017/05/09    14:14:49    ComputerName=XXXXX
5640    2017/05/09    14:14:49    OS=6.1.7601.Service Pack 1
5640    2017/05/09    14:14:49    File=AdlmIntNWFBLicense.cpp,Line=802
5640    2017/05/09    14:14:49    VendorID=3 [FLEXLM-NW]
5640    2017/05/09    14:14:49    VendorError=-1 [Cannot find license file.]
5640    2017/05/09    14:14:49    FLEXLM-NW=v11.13.1.0 build 167164 x64_n6
5640    2017/05/09    14:20:00    Reason=Fatal error
5640    2017/05/09    14:20:00    ComputerName=XXXX
5640    2017/05/09    14:20:00    OS=6.1.7601.Service Pack 1
5640    2017/05/09    14:20:00    File=AdlmIntNWFBLicense.cpp,Line=785
5640    2017/05/09    14:20:00    AdlmIntError=20 [License check out failed]
6820    2017/05/09    14:21:43    Reason=Fatal error
6820    2017/05/09    14:21:43    ComputerName=XXXXX
6820    2017/05/09    14:21:43    OS=6.1.7601.Service Pack 1
6820    2017/05/09    14:21:43    File=AdlmIntNWFBLicense.cpp,Line=802
6820    2017/05/09    14:21:43    VendorID=3 [FLEXLM-NW]
6820    2017/05/09    14:21:43    VendorError=-18 [License server system does not support this feature.]
6820    2017/05/09    14:21:43    FLEXLM-NW=v11.13.1.0 build 167164 x64_n6
6820    2017/05/09    14:36:03    Reason=Fatal error
6820    2017/05/09    14:36:03    ComputerName=XXXXXX
6820    2017/05/09    14:36:03    OS=6.1.7601.Service Pack 1
6820    2017/05/09    14:36:03    File=AdlmIntNWFBLicense.cpp,Line=785
6820    2017/05/09    14:36:03    AdlmIntError=20 [License check out failed]
Replies (12)
Message 2 of 13
Otto
Hello RRAdmin
I understand you are seeing a 0.0.0 error. The following article(s) should help you resolve the problem:
Autodesk 2015 product displays a 0.0.0 error
How to specify license servers using the ADSKFLEX_LICENSE_FILE environment variable.
Troubleshooting FLEXnet Licensing Errors
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 13
Mark.Lancaster
@Anonymous
Can you provide the debug log as defined in the config service tab of your license manager.  Also there was no need to "X" out the numbers..  They are all the same for everybody using that product.  Smiley Wink   In addition make sure "EVERYONE" has full rights to the location of the debug log file.
Also have you review this information?
Mark Lancaster
Message 4 of 13
DarrenP
also is an options file being used?
DarrenP
Message 5 of 13
DarrenP
i think Autocad is looking for an Autocad license that is only for advance steel which Autocad will not use
is there more products in the license file?
DarrenP
Message 6 of 13
the Error is the same for AutoCAD and Advance Steel. Advance Steel needs AutoCAD to run an the license includes AutoCAD.
here is an example:
Message 7 of 13
Hi Mark,
i have alerady tried everythink out of the linked article. it's not getting better.
Here ist the log:
14:15:57 (lmgrd) -----------------------------------------------
14:15:57 (lmgrd)   Please Note:
14:15:57 (lmgrd)
14:15:57 (lmgrd)   This log is intended for debug purposes only.
14:15:57 (lmgrd)   In order to capture accurate license
14:15:57 (lmgrd)   usage data into an organized repository,
14:15:57 (lmgrd)   please enable report logging. Use Flexera Software LLC's
14:15:57 (lmgrd)   software license administration  solution,
14:15:57 (lmgrd)   FlexNet Manager, to  readily gain visibility
14:15:57 (lmgrd)   into license usage data and to create
14:15:57 (lmgrd)   insightful reports on critical information like
14:15:57 (lmgrd)   license availability and usage. FlexNet Manager
14:15:57 (lmgrd)   can be fully automated to run these reports on
14:15:57 (lmgrd)   schedule and can be used to track license
14:15:57 (lmgrd)   servers and usage across a heterogeneous
14:15:57 (lmgrd)   network of servers including Windows NT, Linux
14:15:57 (lmgrd)   and UNIX. Contact Flexera Software LLC at
14:15:57 (lmgrd)   www.flexerasoftware.com for more details on how to
14:15:57 (lmgrd)   obtain an evaluation copy of FlexNet Manager
14:15:57 (lmgrd)   for your enterprise.
14:15:57 (lmgrd)
14:15:57 (lmgrd)
14:15:57 (lmgrd)
14:15:57 (lmgrd) Server's System Date and Time: Tue May 09 2017 14:15:57 Mitteleurop?ische Sommerzeit
14:15:57 (lmgrd) pid 4148
14:15:57 (lmgrd) SLOG: Summary LOG statistics is enabled.
14:15:57 (lmgrd) Detecting other license server manager (lmgrd) processes...
14:15:57 (lmgrd) Done rereading
14:15:57 (lmgrd) FlexNet Licensing (v11.13.1.2 build 173302 x64_n6) started on SVR-CAD-01 (IBM PC) (5/9/2017)
14:15:57 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
14:15:57 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
14:15:57 (lmgrd) License file(s): C:\Autodesk\Network License Manager\SVR-CAD-01005056956d78.lic
14:15:57 (lmgrd) lmgrd tcp-port 27000
14:15:57 (lmgrd) (@lmgrd-SLOG@) ===============================================
14:15:57 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
14:15:57 (lmgrd) (@lmgrd-SLOG@) Start-Date: Tue May 09 2017 14:15:57 Mitteleurop?ische Sommerzeit
14:15:57 (lmgrd) (@lmgrd-SLOG@) PID: 4148
14:15:57 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.2 build 173302 x64_n6 ( build 173302 (ipv6))
14:15:57 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
14:15:57 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
14:15:57 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
14:15:57 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
14:15:57 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
14:15:57 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\Autodesk\Network License Manager\SVR-CAD-01005056956d78.lic -l C:\Autodesk\Network License Manager\Protokolle\debug.log -z -s
14:15:57 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  C:\Autodesk\Network License Manager\SVR-CAD-01005056956d78.lic
14:15:57 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-1024
14:15:57 (lmgrd) Starting vendor daemons ...
14:15:57 (lmgrd) Starting vendor daemon at port 2080
14:15:57 (lmgrd) Using vendor daemon port 2080 specified in license file
14:15:57 (lmgrd) Started adskflex (pid 3244)
14:15:57 (adskflex) Unable to initialize access to trusted storage: 1
14:15:57 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
14:15:57 (adskflex) SLOG: Summary LOG statistics is enabled.
14:15:57 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
14:15:58 (adskflex) SLOG: VM Status: 1
14:15:58 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
14:15:59 (adskflex) Server started on SVR-CAD-01 for:
14:15:59 (adskflex) 86376ADSTPR_T_F (consisting of:		86857ADSTPR_2018_0F
14:15:59 (adskflex) 86612ADSTPR_2017_0F 86507ADSTPR_2016_0F 86490ADSTPR_2015_1F
14:15:59 (adskflex) 86375ADSTPR_2015_0F)
14:15:59 (adskflex) EXTERNAL FILTERS are OFF
14:15:59 (lmgrd) adskflex using TCP-port 2080
14:15:59 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
14:15:59 (adskflex) SLOG: TS update poll interval is 600 seconds.
14:15:59 (adskflex) SLOG: Activation borrow reclaim percentage is 0.
14:15:59 (adskflex) (@adskflex-SLOG@) ===============================================
14:15:59 (adskflex) (@adskflex-SLOG@) === Vendor Daemon ===
14:15:59 (adskflex) (@adskflex-SLOG@) Vendor daemon: adskflex
14:15:59 (adskflex) (@adskflex-SLOG@) Start-Date: Tue May 09 2017 14:15:59 Mitteleurop?ische Sommerzeit
14:15:59 (adskflex) (@adskflex-SLOG@) PID: 3244
14:15:59 (adskflex) (@adskflex-SLOG@) VD Version: v11.13.1.2 build 173302 x64_n6 ( build 173302 (ipv6))
14:15:59 (adskflex) (@adskflex-SLOG@) === Startup/Restart Info ===
14:15:59 (adskflex) (@adskflex-SLOG@) Options file used: None
14:15:59 (adskflex) (@adskflex-SLOG@) Is vendor daemon a CVD: No
14:15:59 (adskflex) (@adskflex-SLOG@) Is TS accessed: No
14:15:59 (adskflex) (@adskflex-SLOG@) TS accessed for feature load: -NA-
14:15:59 (adskflex) (@adskflex-SLOG@) Number of VD restarts since LS startup: 0
14:15:59 (adskflex) (@adskflex-SLOG@) === Network Info ===
14:15:59 (adskflex) (@adskflex-SLOG@) Listening port: 2080
14:15:59 (adskflex) (@adskflex-SLOG@) Daemon select timeout (in seconds): 1
14:15:59 (adskflex) (@adskflex-SLOG@) === Host Info ===
14:15:59 (adskflex) (@adskflex-SLOG@) Host used in license file: SVR-CAD-01
14:15:59 (adskflex) (@adskflex-SLOG@) Running on Hypervisor: VMWare
14:15:59 (adskflex) (@adskflex-SLOG@) LMBIND needed: No
14:15:59 (adskflex) (@adskflex-SLOG@) LMBIND port: -NA-
14:21:43 (adskflex) TCP_NODELAY NOT enabled
The log directory needs rights for everyone? Is the service from lmtools not the only one who writes in the log?
Message 8 of 13
Hi Otto,
behind the first link is no webite.
the things from the second and third link i tried before or where already set.
so the error is alredy there
Message 9 of 13
natasha.l
Hello @Anonymous,
The error is associated with a license file that can not be obtained. Please take a look at the suggested set-up from Autodesk make sure your license file has been generated properly Finding Your Host Name and Physical AddressGenerate a Network License File in Autodesk Account or Requesting a Network License File
Then try to...
Start/Stop Server Manager Service
  1. Locate Lmtools  in C:\Autodesk \Network License Manager (folder)
  2. Make sure the current version of Lmtools 11.13.1.2 is installed
  3. Verify License File, MAC address & HostID with Lmtools System Settings Tab
  4. Config Service Tab > Make sure files are pathed correctly (lmgrd.exe, Lic. File.lic, Debug.log) > Save Service button
  5. Start/Stop/Reread Tab > Select FlexNet Service (should only be 1 Autodesk service) > Check Box Force Server Shutdown > Select Stop Server Button > Uncheck Box Force Server Shutdown > Start Server > Server Start Successful. (should appear below)
  6. Verify users are pulling licenses
Let us know how it goes. Smiley Happy
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Message 10 of 13
Hi Natasha, thanks for your reply.
i have done all steps like they are dicriped in the three articels. The only thing i have not mentioned bevor is that the server is virtualized on vm ware. but everyrhing is done as deskiped.
Message 11 of 13
DarrenP
Was this working before and it stopped working? or did it ever work?
DarrenP
Message 12 of 13
natasha.l
Hello @Anonymous,
Please review the information here: Autodesk Virtualization FAQ
Autodesk can provide recommendations of how to set this up in an ordinary Network Server environment, in this case, I would contact VMware for recommendations on how to do this from their side. Maybe a community member that has set this up can provide some guidance on this @dgladfelter or @Darin.Green
Thank you for posting. Smiley Happy
Message 13 of 13
Darin.Green
Thanks for pinging me on this @natasha.l!
@Anonymous
The new license manager is set to install in C:\Autodesk\Network License Manager\ location now. That being the case, check the following:
  1. Make sure the Network License Manager directory and it's subfiles have the everyone group listed with Full Permission
  2. Make sure all of the paths point to files within the Network License Manager folder.
    • C:\Autodesk\Network License Manager\lmgrd.exe
    • C:\Autodesk\Network License Manager\License\license.lic
    • C:\Autodesk\Network License Manager\logs\debug.log
Let me know if this helps
If this information was helpful, please consider using the Accept Solution
