- Mute
- Permalink
- Report
We have a network deployment for Netfabb Premium 2025 created, but when we do the install on a client computer, it's not getting the network license server info and fails to get a license. The deployment installer's Collection.xml file is correct, has the proper license server / product key / serial number. It doesn't matter if you try to specify the license server info manually, it returns an error 11010 "Server Not Responding". The server is fine, though (see below).
The problem seems to be that the licpath.lic file in C:\ProgramData\Autodesk\AdskLicensingService\A96Q1_2025.0.0.F has "SERVER single 000000000000" and not <servername>
The strange thing is that if I quit Netfabb, and run a a different Autodesk program (AutoCAD, Inventor...) and have no problem getting a license (proving that the earlier error message is inaccurate), then run Netfabb again, it has no problem finding the license server and getting a license. There is a file, nlm-server-info.json that does not get created when running Netfabb first, but is created after running another Autodesk app. When running Netfabb the second time, it will append it's own info to that file.
Any idea why the Netfabb install isn't applying the correct info in the licpath.lic file, or otherwise properly getting a license from the server unless another application has been launched first?
