Navisworks Simulate 2016 cannot find network license
dswann
dswann
Community Visitor
Community Visitor
We installed Navisworks Simulate 2016. The licpath.lic is correct. When starting the program we get A Valid License could not be obtained by the license network manager error (0.0.0) Another workstation with Navisworks Simulate 2015 works fine.
robBouch
Hello @dswann
Welcome to the community!
Are you sure you are pointing to the same server? Can you telnet from the client machine to the license server over port 27000 (or configured port)? Please review your license file in the License Parser to verify that a 2016 license is in there.
If you want to send me the following via private message, I can assist you further:
-license file
-debug.log file
-output of the ‘Perform Status Enquiry’ operation on the ‘Server Status’ tab of LMTOOLS
-options file, if in use
Please click on my @UserName to Send a Private Message
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
robBouch
Hello @dswann
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
