Navisworks Exporters 2022 - create network deployement?
dtiemeyer
Advisor Advisor
Message 1 of 14
dtiemeyer
In versions 2021 and prior of Navisworks Exporters, I was able to create a network deployment that could silently install. How can I do that in version 2022?  When I run Setup.exe all that appears is a local install option.
My other CAD is a Cadillac and I like to Revit to the Max!
Replies (13)
Message 2 of 14
natasha.l
Hello @dtiemeyer
We have an article that provides the adjustments needed in the .bat file to run the deployment silently in 2022 versions.
How to install Autodesk Products silently
Create deployments from Autodesk Account (related article)
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 14
dtiemeyer
Hi Natasha, thank you for the reply, but the Navisworks Exporters does not create a deployment batch file. When you run setup.exe there is no option for network deployment, therefore no option to create a .BAT which would contain silent install option.
Message 4 of 14
dtiemeyer
Hello @natasha.l , did you have the opportunity to look into the Navisworks Exporters 2022 setup?  The download link is below. Please advise, thank you.
https://www.autodesk.com/products/navisworks/3d-viewers
Message 5 of 14
dtiemeyer
@natasha.l  Were you able to look specifically at Navisworks Exporters 2022?  It is not available in my 'Account' to create a deployment with (I have AEC Collection). When I download the installer at the link provided, there are no switches to be run silently, nor an opportunity to create a package.  How can I deploy this program silently?
Thank you.
Message 6 of 14
dtiemeyer
To anyone who may desire to silently install Navisworks Exporters, I've found the 'New to 2022'  SETUP.EXE uses different switches than in previous years. In previous years we could use /quiet or  /qn  to silently install.  The 2022 SETUP.EXE needs the switch   --silent
Therefore, to silently install, I'm downloading the entire package as it extracts itself from the download to C:\Autodesk on the local computer then running the SETUP.EXE --silent  command on that local file.  There may be other techniques, but this one is best for me.  Below is the code for my .BAT   Cheers  -Dustin
IF NOT EXIST "C:\Autodesk\Autodesk_Navisworks_Exporters_2022_Win_64bit_dlm" mkdir "C:\Autodesk\Autodesk_Navisworks_Exporters_2022_Win_64bit_dlm"
XCOPY "\\<<server>>\Autodesk\Navisworks Exporters\2022\Package\Autodesk_Navisworks_Exporters_2022_Win_64bit_dlm" "C:\Autodesk\Autodesk_Navisworks_Exporters_2022_Win_64bit_dlm" /s /h /i
CD C:\Autodesk\Autodesk_Navisworks_Exporters_2022_Win_64bit_dlm
Setup.exe --silent
Message 7 of 14
pmd
Yes but how do you configure the network license?
Message 8 of 14
dtiemeyer
I believe the Exporters do not require a license.
Message 9 of 14
DarrenP
network license for what?
DarrenP
Message 10 of 14
pmd
I can install with the --silent argument, but how do you configure an ini the or equivalent to activate the license for the user?  After the software is installed it requires a network license code to be entered, I can't do this for 100's of devices.
Just after abit of advice.
Message 11 of 14
DarrenP
the exporters don't use a license of any kind
DarrenP
Message 12 of 14
pmd
I don't understand what you mean by an exporter!
Message 13 of 14
DarrenP
that is what this thread is about
its these: https://www.autodesk.com/products/navisworks/3d-viewers?us_oa=dotcom-us&us_si=7c7acd70-e7bc-4315-97b...
DarrenP
Message 14 of 14
Christoph.StulzD4S4Y
Naviceworks Exporters 2022 although installs "Autodesk Desktop App".
Is it possible to disable it for silent install?
Christoph
