Naviswork 2018 giving installation failure -1603 , unidentifiable by autodesk
Naviswork  2018 giving installation failure - 1603, unidentifiable by Autodesk installation manager, Files enclosed Please help.
Otto
Hello rmonga
It looks like you're experiencing an installation error. As there are many different issues that can cause an installation error, it is helpful to provide as much information as possible:
  1. Product Version
  2. Operating system you are using
  3. Name of the Product
  4. Type of License
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
natasha.l
Hello @Anonymous,
Welcome. The computer needs to receive installation information & access Autodesk information externally. Please follow the steps below:
1. Reboot the computer & log in as Administrator
2. Making sure you have full control permissions to these file locations C:\Program Files\Autodesk &      C:\ProgramData\Autodesk
3. Temporarily disable security settings like Antivirus, Firewall & UAC on your Windows operating system
4. Adjust Lan Settings & Proxy Settings, or try a different network location
5. Whitelist the sites listed in these articles:
    What URLs/Protocols Are Accessible for Subscription Licenses
    Single-user Access (formerly Desktop Subscription): Full Site detail for Proxy Whitelisting
    Subscription Licensing – Proxy whitelist
Thank you for posting.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.​​​​​​​
natasha.l
Hello @Anonymous,
I wanted to check-in with you, I hope you were able to resolve the issue with your software.
Please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Nope , I tried all the options it hasn't worked.
Mark.Lancaster
@Anonymous
Your installation is failing for 2 reasons..  You're using the web installer method and its failing to download/install the Autodesk Navisworks Freedom 2018 Language Pack.
Go into Windows Control Panel/Program and Features/Add & Remove programs.  Do you see this language pack?
Yes:  Uninstall it
No:  Run Microsoft Fixit https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed... and select the uninstall function.    When the list of software comes up check to see if the language pack is there.  If it is, remove..  Its not listed there, cancel Microsoft Fixit.
Now to install your product, please use method #1 as indicated in this article
If the installation does fail using that method, please post your installation log file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Good luck on your installation and report back on your progress.
Mark Lancaster
the software did install this time and thank you so much for helping me. But that language Pack didn't showed in either Microsoft registry fixing tool or installed files.
