Message autodesk component if starting up AAM
Hi everyone,
I have a problem with starting up the Autodesk Application Manager. A few weeks ago I updated the AAM. But every time I turned on my laptop (windows 8.1) I recieved this error message:
"Unable to run AAM. It appears AAM service is not available. Please close all instances and retry."
I found the solution to this problem. I changed the proporties of the AAM to run it as an admin.
If I start up my laptop now, a message appears (My language is set to Dutch, so I don't know if this is the exact translation):
"Do you allow the following program to make changes to the computer?
Program: Autodesk Component
Publisher: Autodesk, Inc."
I can choose between the options: YES and NO. I've always selected YES. But the message appears everytime I start up the laptop or the AAM.
I don't know much about computers, but is this supposed to happen? If so, is it possible to disembarrass this message without uninstalling the AAM? I don't want to see this message everytime I open the AAM or start up my laptop.
Thank you
david.lau
Uninstall it and reinstall the Application Manager.  You can follow the steps here:
http://upandready.typepad.com/up_and_ready/2015/07/this-version-of-the-application-manager-has-been-...
David Lau
The same issue after reinstalling the application manager. The message still appears
