maya2019 fixation problem "installation failed "
I have a problem when installing the maya on my machine and you receive a message "installation failed "
- maya2019
-mac os
natasha.l
Hello @Anonymous,
Thank you for posting & sharing this with us, but can you locate the Install Log it will provide information on where the install failed.
  • From the Menu Bar select Go - Go To Folder and then access the following paths:
    /var/tmp/Autodesk
    /private/var/tmp/Autodesk
  • The log will be named after the Autodesk application
  • Please attach the log to your reply
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
leowarren34
Just a quick check: Are you installing as admin with AV disabled?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
natasha.l
Hello @Anonymous,
Just checking in with you, hope you were able to resolve this.
