Maya 2018 does not open
 I use a mac, OS X version 10.11.6.  Installed Maya 2018.  It lets me enter the serial number and then crashes and will not load up.  And now Maya 2016 and 2017 which were working fine, will not load up either.  I did install the update 2 version.  What's going on here?
Otto
Hello scratchynibbler and welcome to the Autodesk community!
It looks like you're experiencing issues with launching your product. The following link(s) should help you resolve the problem:
Troubleshooting why a program does not open
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
natasha.l
Hello @Anonymous,
This could be associated with a systems issue or corrupt installation, it is important to use your system utilities to search for the cause.
You can take a look at the steps below:
  1. Reboot the computer
  2. Check for malware with https://www.malwarebytes.com/mac/
  3. Use safe mode to isolate issues with your Mac
  4. Update or check the graphics card driver on the system
  5. Try to use the Mac Disk Utility to fix a disk problem
  6. Try using Mac Activity Monitor to see what may be interfering in the background while you are trying to launch the application, then uninstall or force quit of that interfering application
  7. Conduct a   Clean Uninstall for MAC  & Use a Browser Download Method in  your Autodesk Account or via the Autodesk Virtual Agent
 Let us know how this turns out.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello @Anonymous,
I wanted to check-in with you to see how you are doing, I hope you were able to resolve the issue & you are up and running now.
