Maya 2016 isnt installing
So for the last few hours ive been trying to install maya 2016 onto my brand new computer. Everything was going smoothly until I actually began the installing process. I tried installing it multiple times and each time it would get about 1/4 of the way dont and quit, a screen would pop up that says "Several items failed to be installed" or something along thkse lines.. Each time it would quit at different lengths into the installation but never really got that far in. I have no clue what it could be, my internet is awful but id assume because the set up s already downloaded that shouldnt matter? Im downloading the windows 64-intel version, but i know im running an AMD processor, would I have to find a different download?
Otto
Hello jaredfrank1997 and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
Welcome to the community..
Without your installation log file we can only speculate what the issue is.   Either post that installation log file or...
I will assume its simply failing due to the method your using so....
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
Here's the log from Autodesk Maya: 2016's failed installation,
Autodesk Direct Connect 2016 and Application Manager also all failed to to install however in order to keep it simple this is all im sending at the current moment. If necessary let me know and I'll send those as well.
Mark.Lancaster
It's failing due to the method you are using. Use the Autodesk Virtual Agent steps I indicated earlier. Also I.guess you didn't read about posting personal info here because your log file you shared still has your serial number in it.
Mark Lancaster
No, I didnt even realize my serial number was even in there. I'll look into erasing it from the board. Thank you for your help.
