Maximum Installs
Maximum Installs
Maximum Installs
I bought a new desktop computer.
I want to remove one of my Student copies (the other copy is on my win 10 laptop) from the old win7 desktop computer and install it on the new windows 10 desktop computer.
Is it as simple as that... just uninstall the copy from the old Win7 computer then do a new install on the new windows 10 computer?
I don't see any way to manage it in 360 or the Desktop App.
I'm looking forward to not having to downgrade dotNET from 4.6x to 4.5 every time there's an update, then re-upgrading .NET to 4.6.x after ACAD's finished updating.
Thanks.
Otto
Hello DBHoag and welcome to the Autodesk community!
It looks like you need help uninstalling - or have issues that may be addressed by uninstalling - an Autodesk product. Community members with similar questions found the following article(s) useful: The following article(s) should help you resolve the problem:
Uninstalling a Product
Once your product is uninstalled, please try downloading your Autodesk Software using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
The link Otto-bot references mentions a stand-alone license (with no definition of what constitutes a stand-alone license).
Is that what a student license is?
Mark.Lancaster
@Anonymous
Since you already have your student license installed on 2 machines, you have reached the max allowed installations for a student.  You can transfer the license off the old machine to the new machine using the License Transfer Utility (LTU) that is located under the Windows Start Menu/Autodesk section.  However the LTU has its issues and it may not work in the end.  You can also try installing the software on the new machine and see if it will just activate without using the LTU interface.  If that works  perform a clean uninstall on the old machine per these instructions.
In the end you may have to contact the Autodesk Educational Support if you run into activation issues since you have already reached the max install for a student license.
Mark Lancaster
OK... well, I uninstalled it according to the instructions given by otto-bot, but I marked yours as the solution because there were quite a few files left in the locations shown on the 'clean uninstall' instructions page, so I was glad to also get rid of all those.
Thanks for your time, and I'll punch the Kudo button too.  🙂
