Maya 2016 extension 2
Fatal error to save in temp how to slove this problem can anyone help me
Otto
Hello Weshal494 and welcome to the Autodesk community!
We noticed you were receiving a fatal error. The fatal error message can indicate several issues. A video card driver update will typically help with this, but fatal errors usually are generic errors, give these steps a try.
  1. Update to the latest certified graphics drivers & Adjust Global Setting to run it
  2. Check the system requirements for the software & make sure you have the required OS updates
  3. Verify the Microsoft Products (Visual C++, Libraries, .NET) properly installed by checking the install log or Control Panel (uninstall/reinstall)
  4. Conduct a Clean Uninstall of the program use MSfixitTool to complete the uninstall
  5. Download all of the parts Autodesk Virtual Agent & Re-Install the product
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
wongam
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to Autodesk Community!
Can you please provide more information so we can understand better:
1) What do you mean by extension 2 in your Maya 2016?
2) What Operating system are you using?
3) You wanted to save a file and Fatal error occur - what file type are you trying to save?
4) Can you please share the Fatal error screenshot?
AmandaWong
Autodesk Customer Support
##- Please type your reply above this line -#
I installed Maya 2016 extension 2 but as I open Maya the fatal error occurs
to save in temp /admin something and then the software crashes and closes
wongam
Autodesk Support
Autodesk Support
Hi @Anonymous,
Sorry to hear that.
What Operating system are you using? Can you share with us from where you downloaded the software? Please share the Fatal error message screenshot so we can investigate further.
AmandaWong
wongam
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Please share more details if the issue still occurs.
AmandaWong
