Material not showing in viewport
Message 1 of 17
Hello everyone,
I'm having an issue with my 3DS Max 2015 x64. It's running on Windows 7 professionnal x64.
In 3DS Max, the materials (or the default color for that matter) doesn't show up in the viewport. I don't see any surfaces. I can only see the edges when I select an object, or always if I check wireframe. I tried changing the options for the material display, and changed the rendering from realistic to shaded to constitent colors, but none of these changed anything.
I did re-install it but the problem still exists.
Thanks in advance for your answers,
Clement.
Replies (16)
Message 2 of 17
Steve_Curley
Customize > Preferences > Viewports. At the very bottom of the dialog "Choose Driver". Try the options, if you have to use anything but the top one (Nitrous D3D 11) then your graphics card is inadequate for running Max (probably an onboard HD4000). If that's the case you need a proper graphics card.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 17
I did use Nitrous D3D11, and except that bug, it worked fine. I just tried Nitrous D3D9 and the bug is gone.
Just to answer you, this computer is my mom's and I needed to install Max on it to work during my holidays. It's not supposed to be used for 3D.
Thank you for the tip about the drivers.
Everything works fine now.
Seeya,
Clément.
Message 4 of 17
What is the different between  between Nitrous Direct 3D 11 and  Nitrous Direct 3D 9 ?
and if Nitrous Direct 3D 11 don't work my view port and i use  Nitrous Direct 3D 9 .. it's okay ?
Message 5 of 17
Steve_Curley
You should find that many things which have been a part of Max for a long time will function perfectly. However, any new features which absolutely depend on D3D11 will almost certainly not. Keep away from new features which may require D3D11 and you should be ok, though long term it's something you should address.
Max 2016 (SP1/EXT1)
Message 6 of 17
Im having this problem but I dont think its something wrong with a 1080 ti that I have... =/
Message 7 of 17
I was having this same issue, in Max 2017 with a geforce 1080. Really frustating.
Switching it to direct x 9, restarting max, switching it back to direct x 11, then restarting max again, seems to have fixed it.
Message 8 of 17
I uninstalled 3D max and installed it back again and it went back to normal. gl
Message 9 of 17
What I have done is to uninstall 3D Max and install it back again and it went back to normal. So if u havent done that try just to clean all files included and just start from start.
Gl m8 I feel ur paint
Message 10 of 17
hai, sir i am woring in 3d designer in 3dsmax same problem for me alos its not rendaring my materials nitrous direct3D 11 is there can you tell me the problem what is hppen and tell me the solutin for that..
Message 11 of 17
ard-nax
Stop! STOP EVERYBODY! Do not uninstall or anything else. I solved finally. I have a GTX 1080Ti so the problem wasn't the graphics card. Just click in the viewport's top left view's preset section (It's shown depending on what you use: [Standard] or [High Quality] etc.). Choise an another one like "Performance", than back to your previous one. And done! This is reloading textures and everything is fine! Hurraaayy!!! 😄
Message 12 of 17
it worked...duude it worked i cant thank you enough man...really appreciate it
Message 13 of 17
Hello!
I am new to 3ds max 2020 and I am unable to change the material of my project although I have followed the basics.
Message 14 of 17
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
This forum is about installation and licensing.   Not sure why workflow or steps regarding 3DS Max is here.
Anyhow you should be posting in the 3DS Max forum where the actual users are: https://forums.autodesk.com/t5/3ds-max-forum/bd-p/area-b200
Mark Lancaster
Message 15 of 17
Also, try to select object you want to show material , then chose DISPLAY option in edit meny (command panel) and change from OBJECT COLOR to MATERIAL COLOR.
that helped in my case
Message 16 of 17
areebaabdulwahid32
Community Visitor
Community Visitor
thanks it worked....
Message 17 of 17
RobH2
Even many years later now, I had an issue with all the materials in a file showing as Gray. I'm very familiar with Max and just couldn't figure it out. Changing the 'Display Color' from the 'Command Panel/Display' settings to 'Material Color' solved it for me thanks to @Anonymous.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
