Announcements
License transfer without old computer
Message 1 of 15
My old computer died. I built a new one. When I tried to re-install AutoCad2012 (Student version) it failed. I read support site and it says I need to have AutoCad on both old and new systems to transfer the license. How can I do that if the old one burned up? I've been looking all over Autodesk site for an answer without success. HELP!!
Replies (14)
Message 2 of 15
what failed?
you need to provide a lot more than this
Message 3 of 15
Inserted disc. AutoCad screen said "Determining Install Requirements". Then I clicked "I Accept". Screen then asked for Serial number and Product key which I entered off the disc container and triple checked. Then I clicked on "Install" for both AutoCad2012 and the Inventor plug-in. The system started to load and then I got the "FAILED" notice...Screen shot attached.
Bob
Message 4 of 15
jeffrey.sin
Hi @Anonymous
Welcome to the Community and thank you for providing the details.
Could you check and try out the suggested solutions from the Autodesk Solutions below?
2012 suite install fails
Error: "Install complete. Some Products Failed to Install"
Kindly let us know if you are now able to install the software. Do ensure that you temporarily disable your anti-virus and firewall before trying to install the software again.
Jeffrey Sin
Autodesk Customer Support
Message 5 of 15
DarrenP
did also look at the log file like the error message says?
how to find the log file: http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
tip on how to read install log files: http://knowledge.autodesk.com/search-result/caas/video/youtube/watch-v-H8mvZhNg-FA-feature-youtube-g...
DarrenP
Message 6 of 15
Jeffery & Darren,
Thanks for suggestions!!
I will look into both sometime today , or tonight and advise ofthe results.
As a quick note, according to the Setup.log, it appears the error is when loading .NET. I will follow the above suggestions/directions and see if that corrects problem.
Message 7 of 15
DarrenP
you can also try this: http://forums.autodesk.com/t5/installation-licensing/install-net-framework-language-pack-failed-inst...
DarrenP
Message 8 of 15
Ok, I uninstalled the AutoDesk/Autocad, .NET Framework, and C++ Redistributable files. I turned off all anti-virus and Firewall protection. Then I ran Setup.
The frist 10 steps seemed to load ok. It started at 7:10pm. When it showed 5 of 15 loading (AutoCad2012) at 7:30 the install then reversed and when it go to 14 of 15, I again got the error mentioned above.
This is a LEGAL Student version running on a Windows 7 Home Premium x64, SP1, 16GB RAM, X99-A MOBO with a i7-5820K Processor.
I don't know what the problem is.I am attaching the Setuo Log file, but don't really understand them. I also have an Install Log and a Content Service Log (I couldn't attach more than one) I had this software on another computer that died. I built the this new one and don't know if the licensing is the cause. I did read that both systems have to be up and running to transfer the license. ANY and all help greatly appreciated!!
Bob
Message 9 of 15
Here's the Install Log...
Message 10 of 15
jeffrey.sin
Aside from the information provided by DarrenP, you can also check out the information in the link below and try out the solutions provided there:
Error 1603 during installation of Autodesk software
Let us know how it goes. Thanks.
Jeffrey Sin
Message 11 of 15
In checking the Install.Log file, I found the following "FAIL" references.
Failed to open the file:F:\x64\acad\acad.cab for computing its hash. Error:2
MSI (s) (08:FC) [19:29:03:068]: SECUREREPAIR: Failed to CreateContentHash of the file: acad.cab: for computing its hash. Error: 2
MSI (s) (08:FC) [19:29:03:068]: Transforming table Property.
I'm not that up of these logs, but I am assuming AutoCad says the file that failed to open on drive F: might be the cause of the failure. How do I change where AutoCad looks because I do not have a drive F:.
Message 12 of 15
I will review and try. Was out of the country till today. Thanks!
Bob
Message 13 of 15
Ok, read DarrenP's response and yours. Tried both. Neither worked. Here's synopsis of latest...
I checked all suggested resolutions and made corrections. After I removed .NET 4.5.1 I tried again. Prior, I got almost immediate errors. After removal, install worked up until about the end of insalling module for AutoCad2012. Install then seemed to reverse from AutoCad 2012 to Consent Service, then Material Library low resolution, the Material Library, etc. The install slide bar showed about 5/8th installed at reversal. The error listed this time was 1619.
Message 14 of 15
I did everything suggested. After removing .NET 4.5.1, install seemed to work... Then about 5/8th of the way on install slider, the whole thing seemed to reverse to beginning of install. The install failed with error 1619 this time. I'm starting to wonder if another CAD program would be MUCH easier!!!
Message 15 of 15
Also, here's the latest setup.log attached.
