License Manager Is Not Functioning
Any ideas?
lanl
Autodesk Support
Autodesk Support
Hi CaSiPearce
For the license manager not functioning issue of 2020 version, you can try steps below:
  1. Sign in to the Autodesk desktop app and install the Autodesk Licensing Service v9.2.2.2501 or the latest update.
  1. After installing the update, restart the system and test the product .
If not works, check other suggestion in Error license manager not functioning or improperly installed with ACAD 2020.
You can post installation/licensing issue in installation and licensing
I move your post to the installation/licensing forum, then experts there can provide more help with this issue.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Lei Lan
Tiana_Y
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @lanl provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
