license-manager-is-not-functioning-or-is-improperly-installed - Autocad 2017
Message 1 of 15
Dear,
I'll describe the whole procedure already carried out and ask for help to solve the problem. I installed autocad 2017 and after all the completed installation procedure, I tried to open the autocad but as soon as the screen trying to open appeared the message "The license manager is not funtioning or is not improperly installed. Autocad will shut down now" then I search the help within the page of Autodesk (https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...)
So I did this procedure and obtained partial success because now when trying to enter the autocad 2017 the message does not appear initially because now opens a box where appears the option to put the serial number and clicking enter the serial number the same message back appears: "the license manager is not funtioning or is not improperly installed Autocad will shut down now." .
Now to my surprise I tried to get in Autocad 2017 but now instead of providing the number of the serial but now by clicking start the trial version and to my surprise, the autocad opened without any problem . This way I can open and use autocad but does not solve my problem because the trial version is only 30 days and then return to have problems, then how do we actually solve the autocad registry problem in 2017?
I use Windows 10, 64-bit - original product.
Attached is some pictures of the problem
help-me please
Replies (14)
Message 2 of 15
Otto
Hello eng.regisnunes1977 and welcome to the Autodesk community!
It looks like you are getting a message saying your product is already installed.
For general assistance with this error, please refer to this thread.
If you are installing an Autodesk software product with a BIM 360 Add-in, please visit this page.
If you are installing an Autodesk 2015 suite, please visit this page.
For help with removing products from your system, please visit Performing a Clean Uninstall and Removing All Products from a Windows System.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 15
Mark.Lancaster
@Anonymous
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
As a reminder, this is a world wide (public) user forum where users are assisting others. In addition do not post (including screen shots) and/or share any personal information (such as your serial #) here.
In the C:\ProgramData\Autodesk\CLM\LGS directory what 2017 folders are there?  Is there a folder called 001I1_2017.0.0.F located there?  If so if you open the LGS.DATA file using NOTEPAD what information is in there?
Mark Lancaster
Message 4 of 15
Dear Lancaster,
Thanks for posting information.
In fact I tried to find the <PRODUCT_KEY> _2017.0.0.F but found that this folder but found two folders within the folder that LGS were named 001I1_2017.0.0.F and 919I1_2017.0.0.F and inside was a file called LGS.data and open with notepad appeared _STANDALONE so I closed the file, deleted in both folders and created a new file with the same name and it wrote _STANDALONE and savei these two folders. However I created a folder called <PRODUCT_KEY> _2017.0.0.F within the LGS folder and also saved the file in this folder but the problem continues.
I uninstalled and installed twice and the problem follows the same.
Message 5 of 15
Mark.Lancaster
@Anonymous
It is not necessary to create a folder called <product key>_2017.0.0.F.  The article meant to substitute <product key> with the actual product key for your application.
Have you tried this steps as well:
  • Disable your Antivirus Software.
  • Remove all files under C:\Users\<username>\AppData\Roaming\Autodesk\ADUT
  • Under C:\ProgramData\Autodesk\ADUT, delete the ProdInd_UserInd.cur file.
  • Go to C:\ProgramData\FLEXnet  and delete any files that start with adskflex.
  • Run your Autodesk product and try activating.
Mark Lancaster
Message 6 of 15
Cowelln
Observer
Observer
Better still - disconnect from the internet (yes, you read that right), and then run it.
Message 7 of 15
I've tried everything said in this site https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
still the message: the license manager is not working... continue to appear...
Message 8 of 15
pghcivil3d
Any resolution on this issue?  We are also having the same issue with IDSP2017.  I just submitted a support request to Autodesk and I'll let you know if they have an answer.
Rob Sinclair
Message 9 of 15
Mark.Lancaster
Is anybody using the Windows 10 Anniversary or the Windows 10 Insider Preview version?  If so these Windows versions are causing a lot of issues with Autodesk products.   Just wanted to check...
Mark Lancaster
Message 10 of 15
I've tried disconnecting network cable -no go. I followed all steps in https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA... -no go. I have ser# and Prod. Key from ADN. I'm a local admin on my workstation, but cannot disable Symantec SEP-12. Besides, online activation is not possible on our DWAN network because of proxy, with any other application too. Installation of Autocad-2017 from the Building Design Suite Premium completed without any problem. The problem happens when I try to start AutoCAD. I click on "Enter a Serial Number" (see screenshots), and after a while I get a popup "The License manager is not functioning or is improperly installed. AutoCAD will shut down now." So, my question is: How can we do manual (offline) activation without Internet connection? It used to be possible in 2015 & 2016 editions, but in 2017 looks like they changed the procedure. OS: Windows 7 enterprise SP1 64-bit.
Message 11 of 15
Mark.Lancaster
@Anonymous
Welcome to the community...
Make sure the following 2 services under Windows services are started and running
Mark Lancaster
Message 12 of 15
It is running. but right after I start my AutoCad 2017 it will stop running... and the error occurs...
Message 13 of 15
As it appeared, my problem was related to some domain GPO conflict, so it's not related to this thread.
Message 14 of 15
natasha.l
Hello @Anonymous,
The license file for a network contains important licensing and server information and is used to configure your server so that you can run the NLM. Confirm MAC address on license file and port 2080@_____ at network set up for the program match up.
Link: https://knowledge.autodesk.com/customer-service/network-license-administration/get-ready-network-lic...
Message 15 of 15
Mine is stand alone
