License error Autocad LT 2020
Message 1 of 23
When we open Autocad LT 2020 and then open a dwg file everything is going fine.
When we don't open Autocad, but open a dwg file directly by double click on the file we get a license check time out.
This is the error we get:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Error-License-checkout-t...
But non of the solutions work and as I said before it's only when we open the dwg file without opening Autocad first.
Someone any idea?
Jessica
Replies (22)
Message 2 of 23
leowarren34
What is the windows default program when opening .dwg files?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 3 of 23
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Is this WIndows service is there and running?
Mark Lancaster
Message 4 of 23
The default program is Autocad LT 2020.
We've tried selecting another program and chance it back to Autocad LT 2020 but no difference.
Message 5 of 23
Yes, the service is running.
When we open Autocad LT 2020 first and than open a dwg file there's no problem and licenses are found.
It's only on double tick on a file, without open Autocad first.
Message 6 of 23
Mark.Lancaster
@Anonymous
What is that service startup set to?  Automatic, delay, etc?
Also is this service started?
If you stop both of them, can you start them again?
Mark Lancaster
Message 7 of 23
@Mark.Lancaster
It's set to automatic.
And it's not a network license, so as far as I thought netflex isn't necessary?
Message 8 of 23
Mark.Lancaster
@Anonymous
Yes that service is still needed for standalone license.  Prior to 2020, that was major service needed to run and activate your product.  So is it running or not?
Mark Lancaster
Message 9 of 23
@Mark.Lancaster
Yes, it's running and started automatically
Message 10 of 23
I have the same problem for Autodesk 2020 products with other details.
When we open Autodesk Products (Autocad, Revit, ...), I have to activate license by click on "Multi-user" :
then I can use and open a Autodesk file. I don't need to specifiy license or port server, I have already saved the information on ADSKFLEX_LICENSE_FILE variable environment.
But at first (like the first connection on the computer), if I open the Autodesk file by double-click, that doesn't work.
There is this step that I need to activate Autodesk Products. Without, It's not ok.
Is it possible to cancel this step and automatically connect to license Server ?
I verify Autodesk services, it's fine for me.
Best Regards
Molyce
P.S : Sorry for my english.
Message 11 of 23
We've solved the problem this morning.
All file association in Windows where set to the right programm.
But, we are using RES Workspace/Ivanti and it's necesarry to add dwg as filetype to the Autocad application.
@Anonymous are you using a similar programm like RES/Ivanti?
Message 12 of 23
Hi Jack,
I'm only an IT aministrator in a high school and I don't know if others software that i have installed can open .dwg file. But we don't use RES Workspace/Ivanti.
In my Windows 10, .dwg file is opened by default with Autocad Application :
Best regards
Message 13 of 23
As a test... do you have the option of setting it to AutoCAD DWG Launcher? Does it help?
Message 14 of 23
Sorry, that didn't work for me. Software always ask me to activate with this windows :
Best regards,
Message 15 of 23
You mentioned this is a multi-user license, does this issue occur on just one PC or multiple computers?
Message 16 of 23
All computers that i can install by imaging in my high school.
Message 17 of 23
leowarren34
What imaging software are you using?
Leo Warren
Message 18 of 23
Fog project
Message 19 of 23
leowarren34
Have you seen this: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Deploying-Autodesk-Softw...
Leo Warren
Message 20 of 23
Yes, I do. I am in the first case "For NLM installations". I have uninstall all products then reinstall them following steps for the 2 situations : that didn't work.
Now, I am going to activate products after imaging for each computers. It will be the only solution to deploy computers fastly.
But I am always looking for a solution for next deployment. If you have an idea, thanks for your response.
Thanks again for your help.
