Inventor 2020 Professional installing on wrong drive
I downloaded Inventor and selected my HDD when it asked where I wanted to install it. After installation finished I found that there is a directory called "Autodesk/WI/Autodesk Inventor 2020" taking up 10.4 Gb of my SSD storage while there is another 3Gb Autodesk file in the HDD. I tried reinstalling but the same thing happened. I manually moved the 10.4 Gb file to my HDD and so far no problems but I am wondering if this will cause problems in the future?
leowarren34
It's not installing on to the 'wrong drive' there are just certain files that are installed on the OS drive (Which I assume to be your SSD).
Long term I don't how stable it will be especially with updates. With most programs there will always be a little bit on the OS drive.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
mdavis22569
This isn't wrong ...
When you started the installation it asks where do you want to extract it:
I have mine going to a cloud location.  You want to keep those folders as you'll need some of the MSI's from it when you do the major updates.
But you're good to move your C:\Autodesk folder and download files to where ever you need to keep it.
Mike Davis
