INVENTOR 2020 1603 EROR
Hello, I try to instal inventor 2020 on windows 7 64 bit, but i have allways 1603 Error mesage. here is the log file, somebody can help me?
I already tryed to change register:  NtfsDisable8dot3NameCreation from 0 to 1. but this wouldn't help.
Mark.Lancaster
@Anonymous
Installation of Autodesk products need to be posted in the installation and licensing forum for best results.  I will have the moderator relocate your posting there for best results.
https://forums.autodesk.com/t5/installation-licensing/bd-p/24
I need to review this log file C:\Users\<username>\AppData\Local\Temp\Inventor2020Install.log
Mark Lancaster
I already tried to uninstall and install again all version of visual c++, still nothing, and I installed 2017 version which installed without any problems.
Mark.Lancaster
@Anonymous
Has nothing to do with C++ installations.  Its related to new licensing mechanism for 2020 (as I suspected).
Update: https://synergiscadblog.com/2019/07/24/autodesk-licensing-mechanism/
But before starting the installation again, make sure the following folder is there C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\9.2.2.2501 and this service is there/started 2020-01-07_18-45-01.jpg
Mark Lancaster
I update autodesk licensing mechanism, and it works, thank you for your help 🙂
