Inventor 2017.4 fails to install
Message 1 of 15
Hello All,
I'm running out of idea as to why the Inventor 2017.4 update keeps failing. I have tried installing it through the Autodesk App, through Browser download, uninstalling and reinstalling Inventor, updating all other Autodesk software first, but nothing.
I've attached the update logs to see if anyone can take a stab at it. Any ideas?
Replies (14)
Message 2 of 15
Mark.Lancaster
@Anonymous
Welcome to Autodesk Community
In Windows Control Panel/Program and Features
Uninstalling the following programs
Autodesk Desktop Connect Service
Autodesk Guide Tutorial plugin
If they will not uninstall, use Microsoft Fixit https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-installed-or-removed and follow the uninstall steps.  Repeat as needed.
Try installation again using the update you downloaded from your Autodesk Account.
Mark Lancaster
Message 3 of 15
Tried your suggestion, but no luck. I've attached the new log files to see if that will help you.
Message 4 of 15
Mark.Lancaster
@Anonymous
Back in Windows Control Panel/Program and Features
Is the Desktop Connect application there or not?   Log is failing on it again..   Just wanted to confirm.
Update:  Also there should be a few log files associated to this update.  Can you zip and attach here.
Mark Lancaster
Message 5 of 15
It wasnt on the Apps & Features list to begin with. The only thing I was able to uninstall was Autodesk Guide Tutorial Plugin.
Message 6 of 15
Mark.Lancaster
@Anonymous
Then use the Microsoft Fixit link and check to make sure its not in the list of applications that can be uninstalled.
Mark Lancaster
Message 7 of 15
I ran Microsoft Fixit and it was not listed on their either. I've attached a new log file for your reference.
You said there are a few other log files associated with the update. What is the file path to those logs so that I can provide them?
Message 8 of 15
Mark.Lancaster
@Anonymous
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Location-of-the-log-files-generated-by-the-installation-of-an-Autodesk-product.html
Mark Lancaster
Message 9 of 15
Attached are the zipped logs from my latest attempt to install 2017.4
Message 10 of 15
m_latz
Your update fails during the stop for/of the "LWS service".
Can you please check if you have one or more processes called "node.exe" in your tasklist ?
regards
Markus
Message 11 of 15
I do not see a node.exe task on my Task Manager under Details.
Message 12 of 15
m_latz
Hhm,
okay can you please make a screenshot of your "uninstall programs" dialog so that we can see which version you have installed:
And can you please also check if you have this folder:
regards
Markus
Message 13 of 15
Looks like I dont have Autodesk Desktop Connect Service
Also, I do have the AutoDesk Desktop Connect folder, however nothing comes up when I type in "forever" in the file path.
Message 14 of 15
m_latz
Okay, I have to test this scenario, but not today, tomorrow.
regards
Markus
Message 15 of 15
I reformatted my laptop with a clean install of Windows. Still getting the same issues. I still do not have Autodesk Desktop Connect Service on my computer either. I attached my new logs for you to review.
