Installing on a computer running windows 10
connor.sterley
connor.sterley
Community Visitor
Community Visitor
Firstly, please could someone clarify for me whether the Entertainment Creation Suite will run on a Windows 10 PC?  I can't find any mention of it, but the system requirements do state a minimum of 7 or 8.
Next, if I am able to successfully run the Suite on my PC -- I am getting the following error when I try to install.  The whole installation run and right at the end I get asked to shut down my monitor.  When I say 'No' the installation is then stopped.
Has anyone else experienced this problem and how do I get around it.
Otto
Hello connor.sterley and welcome to the Autodesk community!
It looks like you are experiencing issues with your product on Windows 10 or want to know which Autodesk products are supported on Windows 10. Community members with similar questions found the following article(s) useful:
Windows 10 support for Autodesk products
Other threads about Windows 10 support
Change your mind about Windows 10? Here's how you can roll back
Please consider bookmarking these pages and checking back often; we'll update with new information as our testing continues.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
@connor.sterley, yes you should be able to install the Entertainment Creation Suite on windows 10. Make sure you install all windows updates (including the Anniversary update) before installing the Autodesk applications.
If this information was helpful, please consider using the Accept Solution
