We have Revit 2016 projects in our data directory that needs to be updated.
Recommended steps for upgrading, found at the Autodesk website (https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/simplecontent/content/file-...) are:
• Open each file in the original version of Revit with Audit checked.
• Use Save As to save the file after auditing.
• Open the file in the target version of Revit with Audit checked.
• Use Save As to save the new version to a different location.
• Once all the files are updated, reload and repath the linked files.
The oldest version of Revit, found on our system is Revit 2017.
I've tried to install Revit 2016 under our license agreement but is will only run on view mode.
Is there a way to install and run Revit 2016 for upgrading purposes?
I think this is a problem for a lot of users.
