Installing AutoCad
Installing AutoCad
Installing AutoCad
Have been trying to install AutoCad for the past few days and when there is about 500mb left to install it just states that some products failed to install..happened with autocad 2014,15 and 16. What seems to be the problem? Please help asap! Thank you!
Otto
Hello rtembo and welcome to the Autodesk community!
It looks like you're seeing the "Some Products Failed to Install" error. This error can be caused if prerequisites have already been installed on the target machine. Incompatible versions, or even the same version, can cause this problem. The following article(s) should help you resolve the problem:
Error: "Install complete. Some Products Failed to Install"
After uninstalling the necessary files, please fully shut down your computer and reboot it for the changes to take effect.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
