Installing Autocad on my laptop
Error Msg..."something is preventing software from launching. Please contact customer support"...
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Download and install per:
1.  Clean out your personal temp (%temp%) folder.  Make sure you have full admin rights, set Windows UAC to never notify and if possible disable your Anti-Virus/Malware scanning utilities. Also the download should occur over a hard wired connection to the Internet and not over WIFI.
2. Access the Autodesk Virtual Agent and follow the download links to your product.
3. Download all of the parts (some applications only have a single part to download) for your product first. This means save each part to your hard drive.  Do not continue until all of the parts have fully downloaded.
4. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
5. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
6. Once the extraction is finished, the installation will automatically start.
7. Follow the installation steps for your product.  At this point you could cancel the installation or create a deployment.
However if the installation does fail using this method, please post your installation log file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Good luck on your installation and report back on your progress.
Mark Lancaster
