Installation Problems
I have downloaded Autocad LT 2017 from my account and attempted to install it several times.  Each time it gets to 8/13 files and then tells me it failed to install.  I have attached the installation log if anybody could help.
Mark
Otto
Hello mark2LF6X and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
Welcome to the community..
Your installation is simply failing due to the method (web installer) you're using.  This method is unreliable and shouldn't be used.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
natasha.l
Hello @mark2LF6X,
Sorry the process was not successful when using the download links from your account. Try the suggested Autodesk Virtual Agent and use this link Preparing Your System for Installation, if you still receive the same failures on the log file.
The following seems to be the issue:
Autodesk Material Library 2017
DirectX Runtime
Microsoft Visual C++ 2015 Redistributable (x64)
Microsoft Visual C++ 2015 Redistributable (x86)
-Uninstall the items listed above in your Control Panel
-If you have a Windows 10 OS install them all back on the machine by visiting the Microsoft website.
OR
-If you have an older OS locate them here to install them back:
Microsoft C++        \Autodesk\(Product)\3rdParty\ (in the x64 and x86) \VCRedist
Autodesk Material Library     \Content\ADSKMaterials
DirectX Runtime        \Autodesk\(Product)\3rdParty\DirectX
Thank you for being a part of the community! Keep us posted on your progress. Smiley Happy
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
