install Passwords
install Passwords
Message 1 of 16
install Passwords
i tryed to install the auto cad but it opens a window with place for the pasword and each time i put the pasword it shows me that it's not correct  what can i do
Replies (15)
Message 2 of 16
Mark.Lancaster
sarra_707
Welcome to the community...
AutoCAD itself does not prompt you for a password to install.  I'm assuming this is a Windows thing that indicates you do not have the proper rights to install software on this machine.
You might give us more details like what version of AutoCAD, your operating system, and a screen shot showing this password entry reqiurements.
Edit:  @Anonymous After installation and when you are trying to activate then you may be prompted for your Autodesk ID/password to run/activate the software.
Mark Lancaster
Message 3 of 16
this is what it showed me and i'm trying to install autocad for mac 2016
Message 4 of 16
mahadeo.thite
Community Visitor
Community Visitor
I also face the problem while installing Inventor on my laptop. It ask me for username and password but it says it incorrect.. everytime says it.. so which login details i should use
Message 5 of 16
nothing to do with Autodesk
this is a windows problem talk to your IT dept if you don't know your log in
Message 6 of 16
mlw2nn
Community Visitor
Community Visitor
mine also does this on a mac
Message 7 of 16
joeodonnell
Community Visitor
Community Visitor
I am having the same issue and cannot get on? Can someone help
Message 8 of 16
pendean
Community Legend
Community Legend
@joeodonnell wrote:
I am having the same issue and cannot get on? Can someone help @Anonymous
This is your OS login, nothing more: it exists because your OS is set up that way, it has nothing to do with AutoCAD
If your "me too" posts actually are related to a separate screenshot or pop-up or OS or..., then you ought to start your own post with your own topic (and your screenshot) for guidance.
HTH
Message 9 of 16
blairk_blairkd_com
Community Visitor
Community Visitor
I am dealing with the same issue on a MAC. did you find a solution? Thanks
Message 10 of 16
DarrenP
do you know your password for the MAC OS?
read this: https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/sfdcarticles/sfdcarticles/...
DarrenP
Message 11 of 16
ahmet.kuzhan
Observer
Observer
try your Mac password. its work. I tried
Message 12 of 16
ahmet.kuzhan
Observer
Observer
its not about Autodesk. that password is your Mac password.
Message 13 of 16
mdavis22569
@ahmet.kuzhan this is a 2016 ticket .../ post ..
Mike Davis
Message 14 of 16
Falaq_118
Community Visitor
Community Visitor
I have the same problem, what do i do?
Message 15 of 16
pendean
Community Legend
Community Legend
No one here can help you with your passwords. Sorry.
Message 16 of 16
dkizer1
Community Visitor
Community Visitor
I FIGURED IT OUT!!! finally...
The password is not AutoCAD related. The pop up window is the MACs way of verifying the installation, so I entered my pin/password that opens the computer.
Hope this helps. @pendean
