Install Error
Install Error
Message 1 of 14
Install Error
No matter how many times i have tried to install//fix Autocad 2017 it doesnt work.
It gets a little bit into the installation then has an issue with my c++ redistribution files and aborts.
i have tried every so called "solution" your support pages have offered.
This problem has been going on for 6+ months now and i need to use it for my uni course.
help!!!!
Replies (13)
Message 2 of 14
ennujozlagam
@Anonymous hello, clear all the files in your temp folder in c drive those cannot delete just skip. you can try to check it HERE. hope it helps. thanks
Message 3 of 14
rudi.roux
Hi Owen,
The "love / hate" relationship between man and machine or in this case, technology continues. I can almost promise you it will be something so small or something which might have been overlooked.
I hope that I can help you through this process, I'm going to refer you to 3x threads where I created posts yesterday, all referring to the same issue.
One of our draughtsman actually had the same problem when it was his turn to upgrade and I managed to rectify it after following the steps outlined in the threads below:
Thread - ONE
Thread - TWO
Thread - THREE
If you already followed these threads, as you mentioned that you already searched the forums for a solution, then, please provide the following:
 - Current OS
 - Version of AutoCAD 2017 which you're trying to install (32 / 64-bit, is it LT?)
 - Possible Error Log?
Hope this helps!
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Message 4 of 14
Mark.Lancaster
@Anonymous
Welcome to the community...
Without your installation log file we can only speculate what the issue is.  However I will assume its based on the method you're using, so
Download and install per:
1. Access the Autodesk Virtual Agent (http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
But if that doesn't resolve your issue then you need to provide us with your installation log file.
Mark Lancaster
Message 5 of 14
Hi mate, thank you for the reply.
Gave it a try, didnt work either.
This is my log:
2016/5/21:22:02:44 OwenC LAPTOP-LK292VME === Setup started on
LAPTOP-LK292VME by OwenC ===
2016/5/21:22:02:44 OwenC LAPTOP-LK292VME Path_Length: 162
2016/5/21:22:02:44 OwenC LAPTOP-LK292VME Current Directory
C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_wi_en-us
2016/5/21:22:02:44 OwenC LAPTOP-LK292VME Launch
2016/5/21:22:02:44 OwenC LAPTOP-LK292VME CommandLine /akamai /sid
a1b3A0000097qodQAA /skipEULA /skipPI /url "
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_wi_en-us_S...
2016/5/21:22:02:44 OwenC LAPTOP-LK292VME Setup Windows update reboot is
pending
2016/5/21:22:03:00 OwenC LAPTOP-LK292VME Setup Autodesk® AutoCAD® 2017 Will
restart automatically.
2016/5/21:22:03:00 OwenC LAPTOP-LK292VME === Setup ended ===
2016/5/21:22:15:46 OwenC LAPTOP-LK292VME === Setup started on
2016/5/21:22:15:46 OwenC LAPTOP-LK292VME Path_Length: 162
2016/5/21:22:15:46 OwenC LAPTOP-LK292VME Current Directory
2016/5/21:22:15:46 OwenC LAPTOP-LK292VME Launch
2016/5/21:22:15:46 OwenC LAPTOP-LK292VME CommandLine /akamai /sid
a1b3A0000097qsfQAA /skipEULA /skipPI /url "
C:\Users\OwenC\AppData\Local\Temp\_AI94CB.tmp
2016/5/21:22:18:01 OwenC LAPTOP-LK292VME === Setup ended ===
2016/5/21:22:15:48 OwenC LAPTOP-LK292VME === Setup started on
2016/5/21:22:15:48 OwenC LAPTOP-LK292VME Path_Length: 162
2016/5/21:22:15:48 OwenC LAPTOP-LK292VME Current Directory
2016/5/21:22:15:48 OwenC LAPTOP-LK292VME Launch
2016/5/21:22:16:34 OwenC LAPTOP-LK292VME Download Play SETUPMARKER
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2016/5/21:22:16:35 OwenC LAPTOP-LK292VME Download Complete SETUPMARKER
2016/5/21:22:16:36 OwenC LAPTOP-LK292VME Download Play SETUP_CONFIG
2016/5/21:22:18:01 OwenC LAPTOP-LK292VME Download Complete SETUP_CONFIG
2016/5/21:22:18:01 OwenC LAPTOP-LK292VME Install CustomCallback Info Invoking
custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck
CB_SOURCE=C:\Users\OwenC\AppData\Local\Temp\_AI94CB.tmp\Setup\AcSetup.dll
2016/5/21:22:18:01 OwenC LAPTOP-LK292VME Install CustomCallback Info Custom
callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/5/21:22:18:02 OwenC LAPTOP-LK292VME PageOpen LaunchDialog
2016/5/21:22:18:12 OwenC LAPTOP-LK292VME PageOpen LicenseDialog
2016/5/21:22:18:12 OwenC LAPTOP-LK292VME PageOpen ProductInfoDialog
2016/5/21:22:18:12 OwenC LAPTOP-LK292VME PageOpen ProductSelectionDialog2
2016/5/21:22:18:17 OwenC LAPTOP-LK292VME PageOpen FullProgressDialog
2016/5/21:22:18:19 OwenC LAPTOP-LK292VME Download Play STARTMARKER
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2016/5/21:22:18:19 OwenC LAPTOP-LK292VME Download Complete STARTMARKER
2016/5/21:22:18:20 OwenC LAPTOP-LK292VME Download Play VCREDIST2008SP1X64
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2016/5/21:22:18:24 OwenC LAPTOP-LK292VME Download Complete
VCREDIST2008SP1X64
2016/5/21:22:18:24 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD
2017\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/5/21:22:18:45 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2008
SP1 Redistributable (x64) Succeeded
2016/5/21:22:18:46 OwenC LAPTOP-LK292VME Download Play UCRT
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2016/5/21:22:18:49 OwenC LAPTOP-LK292VME Download Complete UCRT
2016/5/21:22:18:49 OwenC LAPTOP-LK292VME Installing Universal C Runtime
(KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD
2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/5/21:22:18:49 OwenC LAPTOP-LK292VME Install Universal C Runtime
(KB3118401) Succeeded
2016/5/21:22:18:50 OwenC LAPTOP-LK292VME Download Play VCREDIST2015X86
2016/5/21:22:18:57 OwenC LAPTOP-LK292VME Download Complete VCREDIST2015X86
2016/5/21:22:18:58 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD
2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet
/norestart /log C:\Users\OwenC\AppData\Local\Temp\vcredist_x86_2015.log
2016/5/21:22:19:03 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
Redistributable (x86) Succeeded
2016/5/21:22:19:04 OwenC LAPTOP-LK292VME Download Play VCREDIST2015X64
2016/5/21:22:19:12 OwenC LAPTOP-LK292VME Download Complete VCREDIST2015X64
2016/5/21:22:19:13 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD
2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet
/norestart /log C:\Users\OwenC\AppData\Local\Temp\vcredist_x64_2015.log
2016/5/21:22:19:17 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
2016/5/21:22:19:18 OwenC LAPTOP-LK292VME Download Play DIRECTX
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2016/5/21:22:19:27 OwenC LAPTOP-LK292VME Download Complete DIRECTX
2016/5/21:22:19:27 OwenC LAPTOP-LK292VME Installing DirectX Runtime:
"C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/5/21:22:19:41 OwenC LAPTOP-LK292VME Install DirectX Runtime Succeeded
2016/5/21:22:19:42 OwenC LAPTOP-LK292VME Download Play CM
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2016/5/21:22:22:03 OwenC LAPTOP-LK292VME Download Aborted CM
2016/5/21:22:22:03 OwenC LAPTOP-LK292VME Install Autodesk Material Library
2017 Failed Download Failed, Installation aborted, Result=1603
2016/5/21:22:22:03 OwenC LAPTOP-LK292VME Rollback DirectX Runtime
Failed Failure
is ignored, Result=1619
2016/5/21:22:22:03 OwenC LAPTOP-LK292VME Rollback Microsoft Visual C++ 2015
Redistributable (x64) Failed Failure is ignored, Result=1619
Redistributable (x86) Failed Failure is ignored, Result=1619
2016/5/21:22:22:04 OwenC LAPTOP-LK292VME PageOpen InstallCompleteDialog
2016/5/21:22:23:57 OwenC LAPTOP-LK292VME === Setup ended ===
2016/6/16:13:15:54 OwenC LAPTOP-LK292VME === Setup started on
2016/6/16:13:15:54 OwenC LAPTOP-LK292VME Path_Length: 162
2016/6/16:13:15:54 OwenC LAPTOP-LK292VME Current Directory
2016/6/16:13:15:54 OwenC LAPTOP-LK292VME Launch
2016/6/16:13:15:54 OwenC LAPTOP-LK292VME CommandLine /akamai /sid
a1b3A000009DuzbQAC /skipEULA /skipPI /url "
2016/6/16:13:15:54 OwenC LAPTOP-LK292VME Setup Windows update reboot is
pending
2016/6/16:13:16:01 OwenC LAPTOP-LK292VME Setup Autodesk® AutoCAD® 2017 Will
2016/6/16:13:16:01 OwenC LAPTOP-LK292VME === Setup ended ===
2016/6/16:13:28:39 OwenC LAPTOP-LK292VME === Setup started on
2016/6/16:13:28:39 OwenC LAPTOP-LK292VME Path_Length: 162
2016/6/16:13:28:39 OwenC LAPTOP-LK292VME Current Directory
2016/6/16:13:28:39 OwenC LAPTOP-LK292VME Launch
2016/6/16:13:28:39 OwenC LAPTOP-LK292VME CommandLine /akamai /sid
C:\Users\OwenC\AppData\Local\Temp\_AIDE57.tmp
2016/6/16:13:28:46 OwenC LAPTOP-LK292VME === Setup ended ===
2016/6/16:13:28:43 OwenC LAPTOP-LK292VME === Setup started on
2016/6/16:13:28:43 OwenC LAPTOP-LK292VME Path_Length: 162
2016/6/16:13:28:43 OwenC LAPTOP-LK292VME Current Directory
2016/6/16:13:28:43 OwenC LAPTOP-LK292VME Launch
2016/6/16:13:28:44 OwenC LAPTOP-LK292VME Download Skipped SETUPMARKER
2016/6/16:13:28:45 OwenC LAPTOP-LK292VME Download Skipped SETUP_CONFIG
2016/6/16:13:28:45 OwenC LAPTOP-LK292VME Install CustomCallback Info Invoking
CB_SOURCE=C:\Users\OwenC\AppData\Local\Temp\_AIDE57.tmp\Setup\AcSetup.dll
2016/6/16:13:28:45 OwenC LAPTOP-LK292VME Install CustomCallback Info Custom
2016/6/16:13:28:46 OwenC LAPTOP-LK292VME PageOpen LaunchDialog
2016/6/16:13:29:02 OwenC LAPTOP-LK292VME PageOpen LicenseDialog
2016/6/16:13:29:02 OwenC LAPTOP-LK292VME PageOpen ProductInfoDialog
2016/6/16:13:29:02 OwenC LAPTOP-LK292VME PageOpen ProductSelectionDialog2
2016/6/16:13:29:20 OwenC LAPTOP-LK292VME PageOpen FullProgressDialog
2016/6/16:13:29:21 OwenC LAPTOP-LK292VME Download Skipped STARTMARKER
2016/6/16:13:29:21 OwenC LAPTOP-LK292VME Download Skipped UCRT
2016/6/16:13:29:21 OwenC LAPTOP-LK292VME Installing Universal C Runtime
2016/6/16:13:29:21 OwenC LAPTOP-LK292VME Install Universal C Runtime
2016/6/16:13:29:21 OwenC LAPTOP-LK292VME Download Skipped VCREDIST2015X86
2016/6/16:13:29:22 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/6/16:13:29:23 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
Redistributable (x86) Failed Failure is ignored, Result=1638
2016/6/16:13:29:23 OwenC LAPTOP-LK292VME Download Skipped VCREDIST2015X64
2016/6/16:13:29:23 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/6/16:13:29:24 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
Redistributable (x64) Failed Failure is ignored, Result=1638
2016/6/16:13:29:24 OwenC LAPTOP-LK292VME Download Skipped DIRECTX
2016/6/16:13:29:24 OwenC LAPTOP-LK292VME Installing DirectX Runtime:
2016/6/16:13:29:47 OwenC LAPTOP-LK292VME Install DirectX Runtime Succeeded
2016/6/16:13:29:50 OwenC LAPTOP-LK292VME Download Play CM
2016/6/16:13:32:17 OwenC LAPTOP-LK292VME Download Aborted CM
2016/6/16:13:32:17 OwenC LAPTOP-LK292VME Install Autodesk Material Library
2016/6/16:13:32:17 OwenC LAPTOP-LK292VME Rollback DirectX Runtime
Failed Failure
2016/6/16:13:32:19 OwenC LAPTOP-LK292VME PageOpen InstallCompleteDialog
2016/6/16:13:33:43 OwenC LAPTOP-LK292VME === Setup ended ===
2016/6/16:13:38:56 OwenC LAPTOP-LK292VME === Setup started on
2016/6/16:13:38:56 OwenC LAPTOP-LK292VME Path_Length: 162
2016/6/16:13:38:56 OwenC LAPTOP-LK292VME Current Directory
2016/6/16:13:38:56 OwenC LAPTOP-LK292VME Launch
2016/6/16:13:38:56 OwenC LAPTOP-LK292VME CommandLine /akamai /sid
C:\Users\OwenC\AppData\Local\Temp\_AI48DD.tmp
2016/6/16:13:39:03 OwenC LAPTOP-LK292VME === Setup ended ===
2016/6/16:13:39:00 OwenC LAPTOP-LK292VME === Setup started on
2016/6/16:13:39:00 OwenC LAPTOP-LK292VME Path_Length: 162
2016/6/16:13:39:00 OwenC LAPTOP-LK292VME Current Directory
2016/6/16:13:39:00 OwenC LAPTOP-LK292VME Launch
2016/6/16:13:39:01 OwenC LAPTOP-LK292VME Download Skipped SETUPMARKER
2016/6/16:13:39:02 OwenC LAPTOP-LK292VME Download Skipped SETUP_CONFIG
2016/6/16:13:39:02 OwenC LAPTOP-LK292VME Install CustomCallback Info Invoking
CB_SOURCE=C:\Users\OwenC\AppData\Local\Temp\_AI48DD.tmp\Setup\AcSetup.dll
2016/6/16:13:39:02 OwenC LAPTOP-LK292VME Install CustomCallback Info Custom
2016/6/16:13:39:02 OwenC LAPTOP-LK292VME PageOpen LaunchDialog
2016/6/16:13:39:12 OwenC LAPTOP-LK292VME PageOpen LicenseDialog
2016/6/16:13:39:12 OwenC LAPTOP-LK292VME PageOpen ProductInfoDialog
2016/6/16:13:39:12 OwenC LAPTOP-LK292VME PageOpen ProductSelectionDialog2
2016/6/16:13:39:34 OwenC LAPTOP-LK292VME PageOpen FullProgressDialog
2016/6/16:13:39:34 OwenC LAPTOP-LK292VME Download Skipped STARTMARKER
2016/6/16:13:39:35 OwenC LAPTOP-LK292VME Download Skipped UCRT
2016/6/16:13:39:35 OwenC LAPTOP-LK292VME Installing Universal C Runtime
2016/6/16:13:39:35 OwenC LAPTOP-LK292VME Install Universal C Runtime
2016/6/16:13:39:35 OwenC LAPTOP-LK292VME Download Skipped VCREDIST2015X86
2016/6/16:13:39:35 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/6/16:13:39:36 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
2016/6/16:13:39:36 OwenC LAPTOP-LK292VME Download Skipped VCREDIST2015X64
2016/6/16:13:39:36 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/6/16:13:39:37 OwenC LAPTOP-LK292VME Download Skipped DIRECTX
2016/6/16:13:39:37 OwenC LAPTOP-LK292VME Installing DirectX Runtime:
2016/6/16:13:39:48 OwenC LAPTOP-LK292VME Install DirectX Runtime Succeeded
2016/6/16:13:39:48 OwenC LAPTOP-LK292VME Download Play CM
2016/6/16:13:42:27 OwenC LAPTOP-LK292VME Download Aborted CM
2016/6/16:13:42:27 OwenC LAPTOP-LK292VME Install Autodesk Material Library
2016/6/16:13:42:27 OwenC LAPTOP-LK292VME Rollback DirectX Runtime
Failed Failure
2016/6/16:13:42:28 OwenC LAPTOP-LK292VME PageOpen InstallCompleteDialog
2016/6/16:13:46:37 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/5:21:16:42 OwenC LAPTOP-LK292VME === Setup started on
2016/9/5:21:16:42 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/5:21:16:42 OwenC LAPTOP-LK292VME Current Directory
2016/9/5:21:16:42 OwenC LAPTOP-LK292VME Launch
2016/9/5:21:16:42 OwenC LAPTOP-LK292VME CommandLine /akamai /sid
a1b3A000009aHLdQAM /skipEULA /skipPI /url "
C:\Users\OwenC\AppData\Local\Temp\_AI5A7.tmp
2016/9/5:21:16:54 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/5:21:16:48 OwenC LAPTOP-LK292VME === Setup started on
2016/9/5:21:16:48 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/5:21:16:48 OwenC LAPTOP-LK292VME Current Directory
2016/9/5:21:16:48 OwenC LAPTOP-LK292VME Launch
2016/9/5:21:16:49 OwenC LAPTOP-LK292VME Download Skipped SETUPMARKER
2016/9/5:21:16:49 OwenC LAPTOP-LK292VME Download Skipped SETUP_CONFIG
2016/9/5:21:16:49 OwenC LAPTOP-LK292VME Install CustomCallback Info Invoking
CB_SOURCE=C:\Users\OwenC\AppData\Local\Temp\_AI5A7.tmp\Setup\AcSetup.dll
2016/9/5:21:16:49 OwenC LAPTOP-LK292VME Install CustomCallback Info Custom
2016/9/5:21:16:51 OwenC LAPTOP-LK292VME PageOpen LaunchDialog
2016/9/5:21:17:09 OwenC LAPTOP-LK292VME PageOpen LicenseDialog
2016/9/5:21:17:09 OwenC LAPTOP-LK292VME PageOpen ProductInfoDialog
2016/9/5:21:17:09 OwenC LAPTOP-LK292VME PageOpen ProductSelectionDialog2
2016/9/5:21:17:26 OwenC LAPTOP-LK292VME PageOpen FullProgressDialog
2016/9/5:21:17:26 OwenC LAPTOP-LK292VME Download Skipped STARTMARKER
2016/9/5:21:17:26 OwenC LAPTOP-LK292VME Download Skipped UCRT
2016/9/5:21:17:26 OwenC LAPTOP-LK292VME Installing Universal C Runtime
2016/9/5:21:17:26 OwenC LAPTOP-LK292VME Install Universal C Runtime
2016/9/5:21:17:27 OwenC LAPTOP-LK292VME Download Skipped VCREDIST2015X86
2016/9/5:21:17:27 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/9/5:21:17:28 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
2016/9/5:21:17:28 OwenC LAPTOP-LK292VME Download Skipped VCREDIST2015X64
2016/9/5:21:17:28 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/9/5:21:17:29 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
2016/9/5:21:17:29 OwenC LAPTOP-LK292VME Download Skipped DIRECTX
2016/9/5:21:17:29 OwenC LAPTOP-LK292VME Installing DirectX Runtime:
2016/9/5:21:18:58 OwenC LAPTOP-LK292VME Install DirectX Runtime Succeeded
2016/9/5:21:19:01 OwenC LAPTOP-LK292VME Download Play CM
2016/9/5:21:21:54 OwenC LAPTOP-LK292VME Download Aborted CM
2016/9/5:21:21:54 OwenC LAPTOP-LK292VME Install Autodesk Material Library
2016/9/5:21:21:54 OwenC LAPTOP-LK292VME Rollback DirectX Runtime Failed Failure
2016/9/5:21:21:56 OwenC LAPTOP-LK292VME PageOpen InstallCompleteDialog
2016/9/5:21:22:35 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/5:22:45:24 OwenC LAPTOP-LK292VME === Setup started on
2016/9/5:22:45:24 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/5:22:45:24 OwenC LAPTOP-LK292VME Current Directory
2016/9/5:22:45:24 OwenC LAPTOP-LK292VME Launch
2016/9/5:22:45:24 OwenC LAPTOP-LK292VME CommandLine /akamai /sid
a1b3A000009aIjCQAU /skipEULA /skipPI /url "
C:\Users\OwenC\AppData\Local\Temp\_AI7B90.tmp
2016/9/5:22:45:35 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/5:22:45:29 OwenC LAPTOP-LK292VME === Setup started on
2016/9/5:22:45:29 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/5:22:45:29 OwenC LAPTOP-LK292VME Current Directory
2016/9/5:22:45:29 OwenC LAPTOP-LK292VME Launch
2016/9/5:22:45:31 OwenC LAPTOP-LK292VME Download Skipped SETUPMARKER
2016/9/5:22:45:31 OwenC LAPTOP-LK292VME Download Skipped SETUP_CONFIG
2016/9/5:22:45:31 OwenC LAPTOP-LK292VME Install CustomCallback Info Invoking
CB_SOURCE=C:\Users\OwenC\AppData\Local\Temp\_AI7B90.tmp\Setup\AcSetup.dll
2016/9/5:22:45:31 OwenC LAPTOP-LK292VME Install CustomCallback Info Custom
2016/9/5:22:45:32 OwenC LAPTOP-LK292VME PageOpen LaunchDialog
2016/9/5:22:45:47 OwenC LAPTOP-LK292VME PageOpen LicenseDialog
2016/9/5:22:45:47 OwenC LAPTOP-LK292VME PageOpen ProductInfoDialog
2016/9/5:22:45:47 OwenC LAPTOP-LK292VME PageOpen ProductSelectionDialog2
2016/9/5:22:46:28 OwenC LAPTOP-LK292VME PageOpen FullProgressDialog
2016/9/5:22:46:28 OwenC LAPTOP-LK292VME Download Skipped STARTMARKER
2016/9/5:22:46:29 OwenC LAPTOP-LK292VME Download Skipped UCRT
2016/9/5:22:46:29 OwenC LAPTOP-LK292VME Installing Universal C Runtime
2016/9/5:22:46:29 OwenC LAPTOP-LK292VME Install Universal C Runtime
2016/9/5:22:46:29 OwenC LAPTOP-LK292VME Download Skipped VCREDIST2015X86
2016/9/5:22:46:29 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/9/5:22:46:33 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
2016/9/5:22:46:33 OwenC LAPTOP-LK292VME Download Skipped VCREDIST2015X64
2016/9/5:22:46:33 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/9/5:22:46:34 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
2016/9/5:22:46:34 OwenC LAPTOP-LK292VME Download Skipped DIRECTX
2016/9/5:22:46:34 OwenC LAPTOP-LK292VME Installing DirectX Runtime:
2016/9/5:22:47:01 OwenC LAPTOP-LK292VME Install DirectX Runtime Succeeded
2016/9/5:22:47:02 OwenC LAPTOP-LK292VME Download Play CM
2016/9/5:22:49:38 OwenC LAPTOP-LK292VME Download Aborted CM
2016/9/5:22:49:38 OwenC LAPTOP-LK292VME Install Autodesk Material Library
2016/9/5:22:49:38 OwenC LAPTOP-LK292VME Rollback DirectX Runtime Failed Failure
2016/9/5:22:49:40 OwenC LAPTOP-LK292VME PageOpen InstallCompleteDialog
2016/9/5:22:51:04 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/5:23:10:12 OwenC LAPTOP-LK292VME === Setup started on
2016/9/5:23:10:12 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/5:23:10:12 OwenC LAPTOP-LK292VME Current Directory
2016/9/5:23:10:12 OwenC LAPTOP-LK292VME Launch
2016/9/5:23:10:12 OwenC LAPTOP-LK292VME CommandLine /akamai /sid
a1b3A000009aJ8WQAU /skipEULA /skipPI /url "
C:\Users\OwenC\AppData\Local\Temp\_AI2DDA.tmp
2016/9/5:23:13:25 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/5:23:10:15 OwenC LAPTOP-LK292VME === Setup started on
2016/9/5:23:10:15 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/5:23:10:15 OwenC LAPTOP-LK292VME Current Directory
2016/9/5:23:10:15 OwenC LAPTOP-LK292VME Launch
2016/9/5:23:10:17 OwenC LAPTOP-LK292VME Download Play SETUPMARKER
2016/9/5:23:10:21 OwenC LAPTOP-LK292VME Download Complete SETUPMARKER
2016/9/5:23:10:23 OwenC LAPTOP-LK292VME Download Play SETUP_CONFIG
2016/9/5:23:13:24 OwenC LAPTOP-LK292VME Download Complete SETUP_CONFIG
2016/9/5:23:13:24 OwenC LAPTOP-LK292VME Install CustomCallback Info Invoking
CB_SOURCE=C:\Users\OwenC\AppData\Local\Temp\_AI2DDA.tmp\Setup\AcSetup.dll
2016/9/5:23:13:24 OwenC LAPTOP-LK292VME Install CustomCallback Info Custom
2016/9/5:23:13:25 OwenC LAPTOP-LK292VME PageOpen LaunchDialog
2016/9/5:23:13:43 OwenC LAPTOP-LK292VME PageOpen LicenseDialog
2016/9/5:23:13:43 OwenC LAPTOP-LK292VME PageOpen ProductInfoDialog
2016/9/5:23:13:43 OwenC LAPTOP-LK292VME PageOpen ProductSelectionDialog2
2016/9/5:23:14:49 OwenC LAPTOP-LK292VME PageOpen FullProgressDialog
2016/9/5:23:14:50 OwenC LAPTOP-LK292VME Download Play STARTMARKER
2016/9/5:23:14:50 OwenC LAPTOP-LK292VME Download Complete STARTMARKER
2016/9/5:23:14:50 OwenC LAPTOP-LK292VME Download Play UCRT
2016/9/5:23:14:55 OwenC LAPTOP-LK292VME Download Complete UCRT
2016/9/5:23:14:55 OwenC LAPTOP-LK292VME Installing Universal C Runtime
2016/9/5:23:14:55 OwenC LAPTOP-LK292VME Install Universal C Runtime
2016/9/5:23:14:56 OwenC LAPTOP-LK292VME Download Play VCREDIST2015X86
2016/9/5:23:15:06 OwenC LAPTOP-LK292VME Download Complete VCREDIST2015X86
2016/9/5:23:15:06 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/9/5:23:15:07 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
2016/9/5:23:15:07 OwenC LAPTOP-LK292VME Download Play VCREDIST2015X64
2016/9/5:23:15:16 OwenC LAPTOP-LK292VME Download Complete VCREDIST2015X64
2016/9/5:23:15:16 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/9/5:23:15:17 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
2016/9/5:23:15:18 OwenC LAPTOP-LK292VME Download Play DIRECTX
2016/9/5:23:15:28 OwenC LAPTOP-LK292VME Download Complete DIRECTX
2016/9/5:23:15:28 OwenC LAPTOP-LK292VME Installing DirectX Runtime:
2016/9/5:23:15:46 OwenC LAPTOP-LK292VME Install DirectX Runtime Succeeded
2016/9/5:23:15:46 OwenC LAPTOP-LK292VME Download Play CM
2016/9/5:23:19:06 OwenC LAPTOP-LK292VME Download Aborted CM
2016/9/5:23:19:06 OwenC LAPTOP-LK292VME Install Autodesk Material Library
2016/9/5:23:19:07 OwenC LAPTOP-LK292VME Rollback DirectX Runtime Failed Failure
2016/9/5:23:19:07 OwenC LAPTOP-LK292VME PageOpen InstallCompleteDialog
2016/9/5:23:23:45 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/5:23:24:16 OwenC LAPTOP-LK292VME === Setup started on
2016/9/5:23:24:16 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/5:23:24:16 OwenC LAPTOP-LK292VME Current Directory
2016/9/5:23:24:16 OwenC LAPTOP-LK292VME Launch
2016/9/5:23:24:16 OwenC LAPTOP-LK292VME CommandLine /akamai /sid
C:\Users\OwenC\AppData\Local\Temp\_AI1050.tmp
2016/9/5:23:24:23 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/5:23:24:19 OwenC LAPTOP-LK292VME === Setup started on
2016/9/5:23:24:19 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/5:23:24:19 OwenC LAPTOP-LK292VME Current Directory
2016/9/5:23:24:19 OwenC LAPTOP-LK292VME Launch
2016/9/5:23:24:20 OwenC LAPTOP-LK292VME Download Skipped SETUPMARKER
2016/9/5:23:24:20 OwenC LAPTOP-LK292VME Download Skipped SETUP_CONFIG
2016/9/5:23:24:20 OwenC LAPTOP-LK292VME Install CustomCallback Info Invoking
CB_SOURCE=C:\Users\OwenC\AppData\Local\Temp\_AI1050.tmp\Setup\AcSetup.dll
2016/9/5:23:24:20 OwenC LAPTOP-LK292VME Install CustomCallback Info Custom
2016/9/5:23:24:21 OwenC LAPTOP-LK292VME PageOpen LaunchDialog
2016/9/5:23:24:55 OwenC LAPTOP-LK292VME PageOpen LicenseDialog
2016/9/5:23:24:55 OwenC LAPTOP-LK292VME PageOpen ProductSelectionDialog2
2016/9/5:23:24:59 OwenC LAPTOP-LK292VME PageOpen LicenseDialog
2016/9/5:23:24:59 OwenC LAPTOP-LK292VME PageOpen LaunchDialog
2016/9/5:23:25:07 OwenC LAPTOP-LK292VME PageOpen LicenseDialog
2016/9/5:23:25:07 OwenC LAPTOP-LK292VME PageOpen ProductInfoDialog
2016/9/5:23:25:07 OwenC LAPTOP-LK292VME PageOpen ProductSelectionDialog2
2016/9/5:23:27:30 OwenC LAPTOP-LK292VME PageOpen FullProgressDialog
2016/9/5:23:27:30 OwenC LAPTOP-LK292VME Download Skipped STARTMARKER
2016/9/5:23:27:30 OwenC LAPTOP-LK292VME Download Skipped UCRT
2016/9/5:23:27:30 OwenC LAPTOP-LK292VME Installing Universal C Runtime
2016/9/5:23:27:31 OwenC LAPTOP-LK292VME Install Universal C Runtime
2016/9/5:23:27:31 OwenC LAPTOP-LK292VME Download Skipped VCREDIST2015X86
2016/9/5:23:27:31 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/9/5:23:27:31 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
2016/9/5:23:27:31 OwenC LAPTOP-LK292VME Download Skipped VCREDIST2015X64
2016/9/5:23:27:32 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
2016/9/5:23:27:32 OwenC LAPTOP-LK292VME Download Skipped DIRECTX
2016/9/5:23:27:32 OwenC LAPTOP-LK292VME Installing DirectX Runtime:
2016/9/5:23:27:44 OwenC LAPTOP-LK292VME Install DirectX Runtime Succeeded
2016/9/5:23:27:44 OwenC LAPTOP-LK292VME Download Play CM
2016/9/5:23:30:34 OwenC LAPTOP-LK292VME Download Aborted CM
2016/9/5:23:30:34 OwenC LAPTOP-LK292VME Install Autodesk Material Library
2016/9/5:23:30:34 OwenC LAPTOP-LK292VME Rollback DirectX Runtime Failed Failure
2016/9/5:23:30:37 OwenC LAPTOP-LK292VME PageOpen InstallCompleteDialog
2016/9/5:23:30:58 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/5:23:23:07 OwenC LAPTOP-LK292VME === Setup started on
2016/9/5:23:23:07 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/5:23:23:07 OwenC LAPTOP-LK292VME Current Directory
2016/9/5:23:23:07 OwenC LAPTOP-LK292VME Launch
2016/9/5:23:23:07 OwenC LAPTOP-LK292VME CommandLine /akamai /sid
2016/9/5:23:23:07 OwenC LAPTOP-LK292VME Another Autodesk install/update is
now occurring on this computer. Please wait for that to complete and then
click Retry.2016/9/5:23:45:53 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/5:23:45:53 OwenC LAPTOP-LK292VME Current Directory
C:\Users\OwenC\AppData\Local\Temp\_AI171.tmp
2016/9/5:23:46:08 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/5:23:45:56 OwenC LAPTOP-LK292VME === Setup started on
2016/9/5:23:45:56 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/5:23:45:56 OwenC LAPTOP-LK292VME Current Directory
2016/9/5:23:45:56 OwenC LAPTOP-LK292VME Launch
2016/9/5:23:45:58 OwenC LAPTOP-LK292VME Download Skipped SETUPMARKER
2016/9/5:23:45:58 OwenC LAPTOP-LK292VME Download Skipped SETUP_CONFIG
2016/9/5:23:45:58 OwenC LAPTOP-LK292VME Install CustomCallback Info Invoking
CB_SOURCE=C:\Users\OwenC\AppData\Local\Temp\_AI171.tmp\Setup\AcSetup.dll
2016/9/5:23:45:58 OwenC LAPTOP-LK292VME Install CustomCallback Info Custom
2016/9/5:23:45:59 OwenC LAPTOP-LK292VME PageOpen LaunchDialog
2016/9/5:23:47:47 OwenC LAPTOP-LK292VME PageOpen LicenseDialog
2016/9/5:23:47:47 OwenC LAPTOP-LK292VME PageOpen ProductInfoDialog
2016/9/5:23:47:47 OwenC LAPTOP-LK292VME PageOpen ProductSelectionDialog2
2016/9/5:23:51:15 OwenC LAPTOP-LK292VME PageOpen FullProgressDialog
2016/9/5:23:51:16 OwenC LAPTOP-LK292VME Download Skipped STARTMARKER
2016/9/5:23:51:16 OwenC LAPTOP-LK292VME Download Skipped UCRT
2016/9/5:23:51:16 OwenC LAPTOP-LK292VME Installing Universal C Runtime
2016/9/5:23:51:16 OwenC LAPTOP-LK292VME Install Universal C Runtime
2016/9/5:23:51:16 OwenC LAPTOP-LK292VME Download Skipped VCREDIST2015X86
2016/9/5:23:51:16 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/9/5:23:51:17 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
2016/9/5:23:51:17 OwenC LAPTOP-LK292VME Download Skipped VCREDIST2015X64
2016/9/5:23:51:17 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
2016/9/5:23:51:17 OwenC LAPTOP-LK292VME Download Skipped DIRECTX
2016/9/5:23:51:17 OwenC LAPTOP-LK292VME Installing DirectX Runtime:
2016/9/5:23:51:33 OwenC LAPTOP-LK292VME Install DirectX Runtime Succeeded
2016/9/5:23:51:35 OwenC LAPTOP-LK292VME Download Play CM
2016/9/5:23:57:21 OwenC LAPTOP-LK292VME Download Aborted CM
2016/9/5:23:57:21 OwenC LAPTOP-LK292VME Install Autodesk Material Library
2016/9/5:23:57:21 OwenC LAPTOP-LK292VME Rollback DirectX Runtime Failed Failure
2016/9/5:23:57:29 OwenC LAPTOP-LK292VME PageOpen InstallCompleteDialog
2016/9/5:23:58:32 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/28:16:05:54 OwenC LAPTOP-LK292VME === Setup started on
2016/9/28:16:05:54 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/28:16:05:54 OwenC LAPTOP-LK292VME Current Directory
C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm
2016/9/28:16:05:54 OwenC LAPTOP-LK292VME Launch
2016/9/28:16:05:54 OwenC LAPTOP-LK292VME CommandLine
2016/9/28:16:05:54 OwenC LAPTOP-LK292VME Setup Windows update reboot is
pending
2016/9/28:16:06:06 OwenC LAPTOP-LK292VME Setup Autodesk® AutoCAD® 2017 Will
2016/9/28:16:06:06 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/28:16:12:14 OwenC LAPTOP-LK292VME === Setup started on
2016/9/28:16:12:14 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/28:16:12:14 OwenC LAPTOP-LK292VME Current Directory
2016/9/28:16:12:14 OwenC LAPTOP-LK292VME Launch
2016/9/28:16:12:14 OwenC LAPTOP-LK292VME CommandLine
2016/9/28:16:12:15 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/28:16:12:15 OwenC LAPTOP-LK292VME Current Directory
C:\Users\OwenC\AppData\Local\Temp\_AI30FF.tmp
2016/9/28:16:13:46 OwenC LAPTOP-LK292VME === Setup ended ===
2016/9/28:16:13:11 OwenC LAPTOP-LK292VME === Setup started on
2016/9/28:16:13:11 OwenC LAPTOP-LK292VME Path_Length: 162
2016/9/28:16:13:11 OwenC LAPTOP-LK292VME Current Directory
2016/9/28:16:13:11 OwenC LAPTOP-LK292VME Launch
2016/9/28:16:13:13 OwenC LAPTOP-LK292VME Install CustomCallback Info Invoking
CB_SOURCE=C:\Users\OwenC\AppData\Local\Temp\_AI30FF.tmp\Setup\AcSetup.dll
2016/9/28:16:13:13 OwenC LAPTOP-LK292VME Install CustomCallback Info Custom
2016/9/28:16:13:38 OwenC LAPTOP-LK292VME PageOpen LaunchDialog
2016/9/28:16:14:40 OwenC LAPTOP-LK292VME PageOpen LicenseDialog
2016/9/28:16:14:59 OwenC LAPTOP-LK292VME PageOpen ProductInfoDialog
2016/9/28:16:14:59 OwenC LAPTOP-LK292VME PageOpen ProductSelectionDialog2
2016/9/28:16:15:05 OwenC LAPTOP-LK292VME PageOpen FullProgressDialog
2016/9/28:16:15:06 OwenC LAPTOP-LK292VME Installing Universal C Runtime
(KB3118401):
"C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe"
/S
2016/9/28:16:15:06 OwenC LAPTOP-LK292VME Install Universal C Runtime
2016/9/28:16:15:06 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
"C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe"
/install /quiet /norestart /log
2016/9/28:16:15:13 OwenC LAPTOP-LK292VME Install Microsoft Visual C++ 2015
2016/9/28:16:15:13 OwenC LAPTOP-LK292VME Installing Microsoft Visual C++
"C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe"
2016/9/28:16:15:13 OwenC LAPTOP-LK292VME Installing DirectX Runtime:
"C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe"
/silent
2016/9/28:16:17:21 OwenC LAPTOP-LK292VME Install DirectX Runtime Succeeded
2016/9/28:16:17:22 OwenC LAPTOP-LK292VME Installing Autodesk Material
Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us
SETUP_PACKAGENAME="Autodesk® AutoCAD® 2017"
SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C}
SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0
SETUP_PRODUCTDEPENDENCIES=";;;;"
PACKAGEUPI={D1D649A4-B389-4176-9834-82D80CA33683}
ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2017_English_Win_64bit_dlm\"
FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/28:16:17:52 OwenC LAPTOP-LK292VME Install Autodesk Material Library
2017 Succeeded
2016/9/28:16:17:52 OwenC LAPTOP-LK292VME Installing Autodesk Material
Library 2017 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us
2016/9/28:16:18:22 OwenC LAPTOP-LK292VME Install Autodesk Material Library
2017 - Base Image Library Succeeded
2016/9/28:16:18:22 OwenC LAPTOP-LK292VME Installing Autodesk® Material
Library 2017 - Advanced Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us
SETUP_PRODUCTDEPENDENCIES="{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;"
2016/9/28:16:18:33 OwenC LAPTOP-LK292VME Install Autodesk® Material
Library 2017 - Advanced Image Library Succeeded
2016/9/28:16:18:34 OwenC LAPTOP-LK292VME Installing AutoCAD 2017 Core:
TRANSFORMS="C:\Users\OwenC\AppData\Local\Temp\_AI30FF.tmp\x64\acad\acad-standalone.mst"
ADSK_EULA_STATUS=#1
INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2017\" FILESINUSETEXT=""
2016/9/28:16:25:50 OwenC LAPTOP-LK292VME Install AutoCAD 2017 Core
Succeeded
2016/9/28:16:25:51 OwenC LAPTOP-LK292VME Installing AutoCAD 2017 Language
Core:
TRANSFORMS="C:\Users\OwenC\AppData\Local\Temp\_AI30FF.tmp\x64\en-us\acad\AcadLP\AcadLP-standalone.mst"
ADSK_EULA_STATUS=#1
2016/9/28:16:26:15 OwenC LAPTOP-LK292VME Install AutoCAD 2017 Language Core
Succeeded
2016/9/28:16:26:16 OwenC LAPTOP-LK292VME Installing ACA & MEP 2017 Object
Enabler:
TRANSFORMS="C:\Users\OwenC\AppData\Local\Temp\_AI30FF.tmp\x64\ACAOE\AcaOE-standalone.mst"
ADSK_EULA_STATUS=#1
2016/9/28:16:26:22 OwenC LAPTOP-LK292VME Install ACA & MEP 2017 Object
Enabler Succeeded
2016/9/28:16:26:27 OwenC LAPTOP-LK292VME Installing AutoCAD 2017:
TRANSFORMS="C:\Users\OwenC\AppData\Local\Temp\_AI30FF.tmp\x64\ACADPRIVATE\AcadPrivate-standalone.mst"
ADSK_EULA_STATUS=#1
2016/9/28:16:26:30 OwenC LAPTOP-LK292VME Install AutoCAD 2017 Failed
Installation
aborted, Result=1618
2016/9/28:16:26:33 OwenC LAPTOP-LK292VME Rollback ACA & MEP 2017 Object
Enabler Failed Installation aborted, Result=1618
2016/9/28:16:26:37 OwenC LAPTOP-LK292VME Rollback AutoCAD 2017 Language Core
2016/9/28:16:26:40 OwenC LAPTOP-LK292VME Rollback AutoCAD 2017 Core
Failed Installation
2016/9/28:16:26:43 OwenC LAPTOP-LK292VME Rollback Autodesk® Material
Library 2017 - Advanced Image Library Failed Installation aborted,
Result=1618
2016/9/28:16:26:46 OwenC LAPTOP-LK292VME Rollback Autodesk Material Library
2017 - Base Image Library Failed Installation aborted, Result=1618
2016/9/28:16:26:49 OwenC LAPTOP-LK292VME Rollback Autodesk Material Library
2017 Failed Installation aborted, Result=1618
2016/9/28:16:26:52 OwenC LAPTOP-LK292VME Rollback DirectX Runtime
Failed Failure
is ignored, Result=1603
Message 6 of 14
rudi.roux
Hi @Anonymous,
Ok, so here are a couple of additional things which you could try, but let's start fresh with a to CLEAN UNINSTALL AutoCAD and the also remove .NET and C++ libraries and then reinstall them again followed by reinstalling AutoCAD.
Pre-Installation/Extraction: (SIMPLE PROBLEMS WHICH CAN BE OVERLOOKED)
  • Downloading files from VIRTUAL AGENT will be your best option, start fresh, so re-visit Virtual Agent and Download the Version which you require.
  • Make sure that you put the source installation files to be extracted/setup files in your root drive e.g. - C:\ (By default)
  • Windows sometimes cannot manage to install some components like vcredist or ADSK material library once trying to install from other root drives.
  • Make sure that run everything as administrator or with administrative rights. To be sure that you are, right-click and select the "Run as Administrator".
Windows Related: (POSSIBLE ISSUES)
Are you running Windows 10? Assuming you are, then the C++ files which need to be removed and re-installed can be found HERE
The Windows 10 Anniversary edition updates introduced other issues. So if the C++ files do not resolve your issue, you could also try:
 - Roll back the Windows 10 update. How to do this is explained HERE
STEPS TO FOLLOW NOW: (BREAKDOWN)
Clean uninstall AutoCAD >> Remove .NET & C ++  and re-install >> Virtual Agent, clean download >> Copy Files to correct main drive root (C:\) >> Run Extraction/Setup as Admin >> If prompted with C++ Errors and running on Windows 10, follow Rollback or C++ link for Windows 10.
I hope this will finally resolve your issues! Smiley Happy
Rudi Roux
LinkedIn
Message 7 of 14
Just to make sure, had you read my initial post? I have already tried the
c++ reinstall method. This did not work.
Also the post you are relying to is my response to the virtual agent method
not working.
Yes I do have windows 10. As far I know it isn't the anniversary edition.
Any other ideas
Message 8 of 14
rudi.roux
Hi Owen,
Yes, I did read you original post regarding C++ etc. Have you tried a Clean Uninstall followed by a Clean C++ uninstall and re-install, THEN >> Disk Cleanup C:\ drive and temp files etc. >> Then using the version which you downloaded from VA, copy it to your root drive, then extracting everything with admin rights. In that exact order? As I mentioned, it might be something so small sometimes, sequences can be important.
Before doing the above-mentioned, RollBack your Windows 10, then do the above-mentioned. I know it is tedious and time-consuming to repeat the steps, but you mentioned that you require it for studies, so if it works you'll owe me a beer! haha
Rudi Roux
LinkedIn
Message 9 of 14
Haha no worries will give it a whirl
Message 10 of 14
rudi.roux
Hi @Anonymous,
Will I be seeing that beer anytime soon? haha - OR - are you still struggling?
HERE is something additional which I posted regarding similar issues which served as a solution and HERE is just a link to another thread which served as a solution for someone within the thread.
Rudi Roux
LinkedIn
Message 11 of 14
Haha hi mate. I haven't managed to find a way to go to a lesser version of
Windows without paying. My laptop came with it pre-installed.
Message 12 of 14
rudi.roux
Hi Owen,
What about trying to CLEAN INSTALL WINDOWS 10 ? Something obviously went seriously wrong with the Anniversary Update. And it is sometimes difficult to pin-point the exact problem if I'm not in front of the faulty PC. You'll still be able to run Windows 10, but remember not to run updates after the clean install up to the Anniversary Update, until Windows resolved some of the issues/bugs.
I'm not sure how much data or pre-installed applications you might have on your laptop, but at least doing it this way, you won't need to pay for Windows 8 and this will mean that you start with a fresh copy of Windows 10, which did not give you any issues in the beginning with Autodesk Applications...
Rudi Roux
LinkedIn
Message 13 of 14
Maaaaaaaaaaaaaaaate. It worked! Thank you so much. Bloody legend.
So should I mail you a beer or what haha
Message 14 of 14
rudi.roux
hahahaha! Finally! I was determined to resolve your problem! hahaha
The beer might be warm by the time it gets here, so I'll settle for a Solution or Kudos! haha
Rudi Roux
LinkedIn
